Why are these IS-F tails so cheap??
Found these taillights on e-bay and was confused on why it was so cheap because i thought is-F tails go for about 300 EACH taillight and these are only 250 for both taillights. What's going on? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
http://cgi.ebay.com/ebaymotors/2006-...826176001r1981
F is for Fraud
It is also to be noted that buying on eBay has its pros and cons. While you can find a lot of stuff, most of it is not OEM equipment and you can't really know exactly what you're buying until it is delivered to your front door. And then if you don't like it, returning it is enough of a hassle to drive a completely sane man bat**** crazy.
ohhh i see. so do you guys know if anyone has had any problems with the replicas? i did a search on the forums and i couldn't find any side by side comparisons between the oem and replicas.
hahah niice! i was like refreshing the page and the next minute they were sold. gl with the taillights!
umm they look pretty legit to me. can't really tell that they're replicas. yeah that's true, at this economic stage right now, spending $600 just to clear out the amber signals will make people think you're crazy lol. but i still want to make sure from some people on the forums that these replicas will work just as well as the oem ones.
Of note, the LED pattern on these lights are different than the actual F lights**, so while styled similar, they are different. Make sure what you're interested in, is what you'll actually get.
Edit: ** https://www.clublexus.com/forums/is-...isf-tails.html
I believe Eagle Eye, who has an ebay store, made mine. No problems for me, outside of having to do a slight modification to a connector they came with, to mate snug to the OEM harness. Otherwise, they look and fit identical to OEM. 9/10 on my subjective scale.
i'm definitely going with the e-bay tails now cause i like the LEDs. my only question now is which vendor should i buy it from. Do you think you can find me a reputable seller?
http://cgi.ebay.com/ebaymotors/06-07...Q5fAccessories
someone posted this link in the side by side comparison thread but it says it's only from 06-08 and my car is 09 :/
it is $399.99 SHIPPED for A PAIR of O.E.M. Lexus IS F tail on
http://www.nigel-jdmparts.com/is250350ftailights.html
http://www.nigel-jdmparts.com/isftailight.html
