Dealer Service Oil Change- Now Oil leak
Just want to get it off my chest about this guys, its not a big deal, but another reminder how a simple task can go wrong at the dealer.
I took my car in for 15k oil change only, and tonight i noticed oil where i park in the garage. The good thing the oil is clear, so they did change it...but its been leaking for at least 600 miles. So I have to bring it in tomorrow, and probably waste 2 hrs waiting since its a Friday...always busy.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Not sure how much been leaking, but damn!!!![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Does anyone else had this happened to them? how did you guys handle it? Should I ask for something like discount for next service? or just take an apology from the service guy and walk away?
Thanks
Thanks
edit: i'm a little harsh to judge with this type of scenario because i've done entry-level tech work including oil changes and i've encountered a ton of lazy and careless techs which don't take pride in the work they do causing complaints and a bad rep towards the company they work for
Hey guys, thanks for the responses. Yeah everyone make mistake, especially during a simple oil job...one of those too much repetition 'mistake'.
But gc86 is right, we expect them to be professional at a Lexus dealer, I didn't take my car in for an oil change at Jiffy Lube. Especially, if I didn't noticed the oil now, I could've damage my engine later.
About to head out to the dealer, I feel like asking them for a loaner for the whole day, take it to the Bay area for a date.
But make sure to state how they handle the problem. Bad evaluations is part of having a job in customer service.
This is true but if a entry-level technician working at Lexus cannot complete a simple oil change without properly tightening the drain plug or the filter element canister they shouldn't be doing oil changes on 40k+ cars. My 2 cents.
edit: i'm a little harsh to judge with this type of scenario because i've done entry-level tech work including oil changes and i've encountered a ton of lazy and careless techs which don't take pride in the work they do causing complaints and a bad rep towards the company they work for![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I am curious how the customer is handled in this case.
So far it doesn't reflect well on the service department, considering that double-check procedures must be part of the process.
Could have been a bad gasket and the leak might not have shown up while in the shop. I don't believe you mentioned how much oil was under the vehicle, but it appears that it wasn't enough for you to feel that you needed to add any to drive safely.
