Going up hill driveways at an angle: How do you coilver brotha's deal?
#46
areukhmr and i shaved the tab quite a bit to help prevent it from rubbing much on his new setup. the only option you have now since your tab is broken is fabricate your own tab and angle it up so it doesnt rub against it. pm me your information, i'll be up north this weekend we'll take a look at it and help you figure out a solution to your problem.
#51
i dont have pixs, but if you take a look at the mounting tap where the 10mm bolt up the bumper to the fender. All you need to do is unbolt that bolt, remove the plastic on the fender where the bolt screw in to (holding the bumper and fender together), drill a new hole further back ( toward the front end), get a new set of bolt/nut ( i used a 10mm bolt), bolt the bumper back up using the new location, and cut off as much as possible of the old mounting point.. hope that help.. GL bro.
#53
Ok, I kind of get it. You drill a new hole into the bumper? and then bolt the bumper back up to what tho? Before you had to use the tab that was connected to the fender. Now what do you bolt the bumper to? Do you just throw away the old plastic that use screwed into? Did you have to take the bumper off to do this? Sorry for the questions, i just want to make sure im doin this right. Thanks
#54
areukhmr and i shaved the tab quite a bit to help prevent it from rubbing much on his new setup. the only option you have now since your tab is broken is fabricate your own tab and angle it up so it doesnt rub against it. if you can get pictures of what your fender looks like now i'll figure out a way where we can tap a new tab for you to hold your bumper to your fender
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
#55
XenonES3
03-11-03 03:08 PM
