Has this happened to anyone before please help freakin out here
ok so i was in the car i had it in acc mode for about 5 mins max then i went to go turn it on put my foot on the brake and push the start button and the car lost all power so i popped the hood chk my battery terminals and soon as i was about to chk the terminals the car got pwer again and went bk to acc mode my music came back on the nav screen had rebooting disc do not turn of power on it and it went bk to normal the car turned on and then when i tried to roll my windows down from the drivers side i wasnt able to. I am able ot roll the windows down from the actual door but not from the drivers door i can only roll the drivers window down from the driver side non of the other ones. i looked and the little green light on all the other doors window switch was flashing don't know what that means and i have no idea where the fuse is located or if it is even a fuse problem i opened the big fuse box which has the ac fan and the tail light fuses in it but no fuse in there for windows i have a mobilehid kit with the wire harness so its not drawing power from the cars electrical system except a small amount to trigger the relay. please help i have no idea whats going on and its freakin me out
thanks
thanks
2IS OG
Searching the stickied FAQ thread:
https://www.clublexus.com/forums/is-...tart-here.html
Would have yielded this thread:
https://www.clublexus.com/forums/is-...isconnect.html
Which solves your window problem. Calm down and check it out, there's lots of good stuff in there.
Javier
Javier
roll each one of ur windows down from each window and roll them back up and the blinking will disappear. not to mention, u will have windows control on ur driver side back. everytime u disconnect the battery terminal u have to do this process. it's in ur lexus manual.
