How often do you guys check tire pressures?
09-02-09, 08:42 AM
How much air is lost every time it’s checked?
09-02-09, 09:12 AM
Quote:
Originally Posted by
Xavier6162
If you do it right, almost nothing.
09-02-09, 09:15 AM
Every other month. I have a compressor in my garage so I can avoid the junky pumps at gas stations.
09-02-09, 10:37 AM
i check it at least once a month.. As for air loss honestly its not much maybe 2-4 pounds if that.
09-02-09, 11:19 AM
I run my rears at 21 psi and the fronts at 38 everyone always thinks I have flat tires and I check whenever I race or wind up at a track
09-02-09, 11:34 AM
haha, i never check... just fill up when the "low tire" sign is on...
lazy me, i know....
my other car without the TMPS, i check it once in a while.... +/- month
09-02-09, 02:02 PM
lobuxracer
Every month or when the seasons change. Temperature has a big influence on tire pressure.
+1 I agree - 1x/month or w/ chnge of weather
09-02-09, 02:48 PM
I'm more conscience of seasonal changes like some have mentioned above with our cars that have TPMS. Cars without it, like my SC, I usually check monthly.
09-02-09, 04:12 PM
DaRacerz
Personally, I've just programmed the TPS at 34-lbs. If it falls under 30-psi, it'll warn on the dash. No need to check the tires when technology is on your side.
How do you do that??
LexStylez
09-17-11 05:39 AM
niteflite
02-26-10 11:21 PM
BlitzSix
11-13-08 05:54 AM
JASP615
GX - 1st Gen (2003-2009)
19
10-31-07 11:54 AM
MD350
ES - 5th Gen (2007-2012)
15
10-17-07 11:26 PM
