Cant believe this happened
Old 09-01-09, 07:54 PM
kams229
kams229's Avatar
Default Cant believe this happened
Well it hasn't even been a week since I had my bags installed, so today Im leaving work just about to pull out into the highway when all of a sudden my front driver side feels like it completely bottomed out. i get out of my car to find my front driver rim is completely towed in. So i slowly air up the bags and reverse into the parking lot. As i look behind the rim what do i find my nut which holds the steering knuckle and upper arm is gone HOLY **** !!!!!!!!!!!!! Well I go take a look at the other side and the nut is there but those DUMB ***** forgot to put in the pin which holds the nut to the bolt. Just cant believe this happened well at least it happen in the drive way instead of rolling down road. The shop that installed the bags is going to have to flat bed it back to the shop tomorrow morning,I'll be sure to go over their work thoroughly before i get it back out on the road.
Old 09-01-09, 07:56 PM
phongh
phongh's Avatar
that **** sucks bro. You're lucky that didn't happen on the road.
Old 09-01-09, 07:59 PM
Wierdazndu
Wierdazndu's Avatar
dude that ****IN sux! good luck with everything.
Old 09-01-09, 08:02 PM
kams229
kams229's Avatar
I know on my way home there is a stretch of highway which everyone runs 70-80 mph could you imagine how bad that could of been! Not to worried about the car that is material and can always be fixed and replaced but just concerned about my safety
Old 09-01-09, 08:03 PM
Robs IS250
Robs IS250's Avatar
and WHAT shop did you take it to???
Old 09-01-09, 08:04 PM
kams229
kams229's Avatar
Easy fix just need a new castle nut a two pins to secure them. Just still so mad someone could be so careless to forget something so important
Old 09-01-09, 08:06 PM
kams229
kams229's Avatar
Wheel shop up here in Destin Fl.
Old 09-01-09, 08:07 PM
Robs IS250
Robs IS250's Avatar
make sure your fender, wheel, bag set-up, suspension is ok!
Old 09-01-09, 08:13 PM
kams229
kams229's Avatar
Yeah everything seems to be fine. right before i was on my way I was showing one of my employees how high it raises up. i guess thats when the bolt from the front the upper arm raised out from the steering knuckle .After that i backed it up only about 30ft.
Old 09-01-09, 08:40 PM
trixxx519
trixxx519's Avatar
wow what kinda shop does that, so careless
Old 09-01-09, 08:48 PM
iSuxeL
iSuxeL's Avatar
Bad install dude. Sorry to hear.
Old 09-01-09, 08:51 PM
Kevin.IS
Kevin.IS's Avatar
Sorry to hear hope everything works out.
Old 09-01-09, 08:53 PM
kams229
kams229's Avatar
Everything always seems to work itself out one way or another
Old 09-01-09, 09:42 PM
nmpeter
nmpeter's Avatar
I saw this thread and I got scared as hell it was something with the KSport system. I'm glad nothing happened though, it could have been worse.
Old 09-02-09, 07:44 PM
AS~IS
AS~IS's Avatar
Dang... I'm sorry to hear that man. Body shop horror stories popping back up... :/
Quick Reply: Cant believe this happened
