Staggered setup on AWD ! - The Mother Thread - !
Old 03-22-12, 06:14 PM
  #211
Nicecar
Nicecar's Avatar
Default Updated 07 IS250 AWD Staggered setup
Hello everyone
Here is an update to my setup.
- What is your exact wheel/tire setup ?
Front
Tires Invo 225/40-18
Wheels IS350 18"X8"
Rear
Tires Invo 265/35-18
Wheels IS350 18"X8.5"
I added B2Design wheel spacers
15mm front
20mm rear
- How many miles you've been running this for ?
Just installed them less then 3k miles
- Are you noticing any issues (gas millage ect...)
No
- Also post your general thoughts/comments
lowered with Hotchkis springs
Old 04-01-12, 06:14 PM
  #212
ddhleigh
ddhleigh's Avatar
Would you guys go vossen 19" cv1 staggered on a non lowered awd? Regardless, which wheel size is best?
19 x 8.5 front
19 x 10 rear
Not sure on off set.
Old 04-01-12, 08:26 PM
  #213
laobo979
laobo979's Avatar
At least go with a 19x9+35 front and 19x10+35 but with out a bit of a drop it's gonna have a good amount of gap in the wheel well.
Old 04-01-12, 08:50 PM
  #214
ddhleigh
ddhleigh's Avatar
Don't think CV1's come in 19x9
Old 04-09-12, 03:01 PM
  #215
kevin250is
kevin250is's Avatar
Brought my car to the dealer today to install my summer rims. I have the 19 inch genesis track wheels.
Front:19x8
Rear: 19x8.5
My tire guy recommended 225/35/19 in the front and 255/30/19 in the rear, but lexus is telling me its going to cause a problem. What do you guys think?
I'm driving an 07 AWD is250 dropped on H&R springs.
Old 04-09-12, 03:06 PM
  #216
laobo979
laobo979's Avatar
You should be fine that real close to rolling diameter. Just keep an eye out on your tread wear. Unlike rwd you can't just replace one or two tires. Must replace all four depending if there new. I ran 235-35/265-30-19 and the dealer said I'm ok as long as I know to keep the tire wear even.
Old 04-09-12, 03:22 PM
  #217
kevin250is
kevin250is's Avatar
How did it drive?
Did you have any warning lights go on, traction control out of whack, speedometer off, etc?
Old 04-09-12, 08:05 PM
  #218
XZOTIK1
XZOTIK1's Avatar
Default Before i order these wheels
19X8 +35
19X10 +35
F/235-35-19
R/265-30-19
Will this work on my IS250 AWD ?????
Attached Thumbnails Staggered setup on AWD  ! - The Mother Thread - !-dscn3341.jpg   Staggered setup on AWD  ! - The Mother Thread - !-dscn3342.jpg
Old 04-09-12, 08:13 PM
  #219
XZOTIK1
XZOTIK1's Avatar
Default this is my other choice
Bolt Pattern: 5x114.3 Rim Width: 8.5F & 9.5R
Hub Bore: 60.1 Rim Diameter: 19
Rim Brand: OE Replica Offset: +38F & +45R
What size tires should i go with?????
Attached Thumbnails Staggered setup on AWD  ! - The Mother Thread - !-lx520-hb-front.jpg   Staggered setup on AWD  ! - The Mother Thread - !-me-lf-a-5.jpg
Old 04-10-12, 01:59 AM
  #220
AndysIS
AndysIS's Avatar
19x8.5 +39 up front with 19x10.5+?? not sure yet will this work with 225/35/19 235/35/19?
Old 04-10-12, 09:56 AM
  #221
laobo979
laobo979's Avatar
It will work if you want a really stretch out in the rear. But depending on the offset.
Originally Posted by kevin250is
How did it drive?
No issues when i had it like i said as long as you have the right size tires.
Old 04-10-12, 10:01 AM
  #222
laobo979
laobo979's Avatar
Originally Posted by XZOTIK1
19X8 +35
19X10 +35
F/235-35-19
R/265-30-19
Yes you can also run 225-35/255-30
Same with the above
Old 04-12-12, 08:58 AM
  #223
XZOTIK1
XZOTIK1's Avatar
Thanks, that good new for me. Now I just have to make a choice. My 250 is Starfire Pearl. What do you guys think? LFA's or ADR's
Old 04-19-12, 06:35 AM
  #224
tbulsara
tbulsara's Avatar
I have a 2008 IS250 AWD.
Currently sitting on 20" staggered.
fronts: 8.5 245/30/20 nitto invo
rears: 10 285/25/20 nitto invo.
runs great, no rubbing. I had to lower the car because it looked like a truck
been running this setup for over a year. atleast 20000 miles if not more.
no warning lights. even wear all around.
Old 04-19-12, 06:36 AM
  #225
tbulsara
tbulsara's Avatar
Quick Reply: Staggered setup on AWD ! - The Mother Thread - !
