Staggered setup on AWD ! - The Mother Thread - !
Old 08-21-12, 01:02 PM
  #256
laobo979
laobo979's Avatar
CJITTY You should be good with the size your running rite now. The IS/GS are a 30/70 split so not the same as the LS awd. But rule of thumb still applies closer you are to the rolling diameter the better. As for the warning light comming up i dont even think there one. I know there was a member who drove around with the wrong tires on didnt know till the rear diff shaft snapped. The 255-30 should work but i ask a tire shop like tirerack. They can give you a true answer on that.
Old 08-21-12, 02:40 PM
  #257
CJITTY
CJITTY's Avatar
Hey thanks..I spoke to Discount Tire and they told me that since I rarely travel at high speeds or long distances to just run out the 245/30s and then switch up to 255/30 fronts when I really need to..i will keep it at near max psi to make sure I keep the tire holding up as much as it should. I have been told that tire load ratings are very conservative in their estimates assuming folks are going to go overboard lol
As far as the AWD, is the IS/GS always 30/70 or does it vary like the LS's? I found this section of an article below regarding the LS AWD system:
"All-wheel drive is available on the non-hybrid models, also, and it features a Torsen limited-slip center differential to distribute torque between the front and rear tires. Normally, the front-to-rear torque split is set at 40:60 but it can vary between 30:70 and 50:50 depending on driving conditions. The bottom line is stable traction in any conditions"
I have the hybrid so I wonder if it is different due to the hybrid system regenerating power back to battery, etc.
Old 08-21-12, 02:47 PM
  #258
RDIS250AWD
RDIS250AWD's Avatar
Rohana RC10
20x9 2.5" lip +35 Front
20x10 2.5" lip +40 rear
Falken FK452 tires
245/30/20
275/30/20
Old 08-21-12, 02:50 PM
  #259
tbulsara
tbulsara's Avatar
i had to run 245/30/20, 285/25/20.
i had the stock 250RWD wheels for a day and the AWD warning came on.
Originally Posted by RDIS250AWD
Rohana RC10
Falken FK452 tires
245/30/20
275/30/20
Old 08-21-12, 02:58 PM
  #260
RDIS250AWD
RDIS250AWD's Avatar
the light prob came on bc those 250rwd wheels tpms wasnt synced with your car.
Old 08-21-12, 05:56 PM
  #261
laobo979
laobo979's Avatar
Like i say im not to sure about the LS Hybrid. That something you can find online. But remember if your gonna replace the front you'll need to do the back as well. With AWD it must be even thread wear all the time. So no mix match tires.
Old 08-27-12, 10:13 AM
  #262
tbulsara
tbulsara's Avatar
Nope, the TPMS was synced fine, It was because the Diameter was diff front and back Hence the AWD warning and not tire pressure warning., I asked the dealer and they said that when that happens, it kicks off the front and only the rear push as a precaution.
Old 09-01-12, 05:43 PM
  #263
diz2IS
diz2IS's Avatar
Hey guys, I've been planning on getting some wheels for my is250 awd but am dropping it first. Got some coilovers coming in and was wondering if it would be okay to drop my car 25" from fender to ground on oem wheels? Thanks
Old 09-01-12, 08:32 PM
  #264
RDIS250AWD
RDIS250AWD's Avatar
post in this thread buddy
https://www.clublexus.com/forums/is-...tart-here.html
Old 09-02-12, 11:01 AM
  #265
diz2IS
diz2IS's Avatar
ah, I've already gone through that thread, just wanted to know if it was fine to drop on oem wheels... I've been reading over the past few months now which is why i have few posts. just gonna do an even drop torqued to specifications and get an alignment and i figure ill be good?
Old 09-02-12, 09:44 PM
  #266
Tasty
Tasty's Avatar
Default VIP Modulars VR-12s
Here's a fitmet for AWD IS250
Fronts 19x10.5 235/35
Rears 19x11.5 245/35
Attached Thumbnails Staggered setup on AWD  ! - The Mother Thread - !-hellaflush.jpg
Old 09-02-12, 11:30 PM
  #267
laobo979
laobo979's Avatar
Looks good tasty but if you don't post up your offset you'll be hated on here.
Old 09-19-12, 12:23 AM
  #268
darksparkz
darksparkz's Avatar
Rohana RC10
Falken FK452 tires
245/30/20
275/30/20
Do you have any rubbing in the rear? How much camber do you have? Is fenders rolled?
Old 09-19-12, 12:27 AM
  #269
itzhieu
itzhieu's Avatar
i miss having awd :[[
Old 09-19-12, 12:54 AM
  #270
RDIS250AWD
RDIS250AWD's Avatar
Slight rub depending on how i turn nothin that bothers me and no fenders aren't rolled liners aren't modified either. Not much camber wear but i haven't had these too long either
Quick Reply: Staggered setup on AWD ! - The Mother Thread - !
