Staggered setup on AWD ! - The Mother Thread - !
#292
Hello, i think the offset is 45. Will they fit my IS250 AWD ?
Here's a link to what they are. It's the original Lexus 18 mags.
http://is.sewellparts.com/accessorie...2009/1883.html
Thanks!
Thanks!
#293
Anyone?
Please help!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Please help!
Thanks!
Thanks!
#295
Ok just to confirm.. I want to make sure I'm understanding this correctly.
Do I want the new wheel diameter to be as close to stock as possible?
OR
Do I want the new wheel diameter between the front and rear wheels to be as close as possible?
I guess ideally, both would be best.
I'm trying to figure out what tires to get for wheels that are 19x9 +36 and 19x10.5 +42.
OR
#296
the wheels can be any size, as long as the tires that you put on have as close as possible rolling diameter front and back. offsets don't matter.
just look online for a tire rolling diameter calculator and that will help you out, you can punch in the numbers and it will tell you the difference.
keep it as close as possible otherwise the AWD light will come on.
#298
Any help would be appreciated
#300
Question, if im running the same four tire sizes and wheel size, then i should be okay right? Im not running staggered but would it matter how big or small my tires are...? ill be running 19x9.75 all around.
