Staggered setup on AWD ! - The Mother Thread - !
Old 08-10-13, 08:10 AM
  #331
SNiiP3R
SNiiP3R's Avatar
Anyone had any problems with staggered on an AWD?
Old 08-10-13, 01:34 PM
  #332
CJITTY
CJITTY's Avatar
Not that I heard of. I just got a new set of staggered 22s running 255/30 front and 305/25 rear on my LS600hL. Previously had 245/30 front and 295/25 rear for over a year..no issues either
Sent via Club Lexus Mobile App
Old 08-13-13, 03:00 PM
  #333
sm1ke
sm1ke's Avatar
This thread is here for a reason. Of course there are problems running a staggered setup on an AWD drivetrain, but they usually only arise when the staggering is done incorrectly. Basically, keep the front and rear rolling diameter as close to the same as possible. For example, my fronts are 235/35/19, and my rears are 275/30/19. This translates into a .08% difference front to rear. Haven't come across any problems yet in the 3 or 4 months I've been running this setup.
Also, make sure all 4 tires are the same so they have the same tread pattern, and also make sure they all have about the same amount of treadwear remaining.
Old 08-13-13, 06:25 PM
  #334
CJITTY
CJITTY's Avatar
Well stated
Old 08-22-13, 12:50 PM
  #335
jimmyjam
jimmyjam's Avatar
So Im at the mechanic right now trying to install my ISF 19 inch rims on my is 250awd, and the mechanic is giving me a lot of doubts.
The rims are as follows in the pic an the tires are
front: 225/40/19
back 255/35/19
I have read that the 18s run fine with it below, and most people with the same setup with none AWD is doing well with it, so Im guessing it should be ok. What do you guys think.. a quick response would be amazing ... since my car is probably on the hoist as we speak ! lol
My AWD runs on 18' stockies 225/40 front and 255/35 rear. Perfect size and zero problems
__________________
--From Russia with love--
'06 Lexus IS250 AWD (unofficially imported )
Mods: JDM LED mirrors, 4300k HID lows, 5000k IPF halogen highs, Polarg LED parking lights, DRL off, 4300k HID fogs, hacked dashboard ECU, complete measurement conversion, fogs on without lowbeam, 82% tint all around, staggered OEM Sport R18 wheels
Read more: https://www.clublexus.com/forums/is-...#ixzz2cjGdHauV
Old 08-22-13, 03:16 PM
  #336
laobo979
laobo979's Avatar
front: 225/40/19
back 255/35/19
__________________
18 vs 19 are too different diameter just cause it works for on size doesn't mean it universal for any size. Your installer is correct not to do it. I suggest you do your home work on what works. Other wise it will cost you more in the when it breaks. Those tires size on the spec are RWD isX50 not awd .
Old 10-09-13, 08:25 AM
  #337
sm1ke
sm1ke's Avatar
^^^ What laobo979 said. Wheels will be fine, tire size is not. You would be better off going with 235/35 up front and 275/30 in the rear. With those tires, the wheel diameter will be as close as possible when comparing the front wheels with the rear wheels.
Old 10-25-13, 02:36 PM
  #338
LexusIS954
LexusIS954's Avatar
I just installed 245/30/20 front and 275/30/20 rear and I haven't had any lights come on. The only issue that I have run into is some bad rubbing in the rear. Has anyone ever tried this setup?
Old 10-26-13, 11:18 AM
  #339
DeanIS
DeanIS's Avatar
I am looking at 18x8 ET41 and 18x9 ET45. Will this setup work on my 2010 AWD? And, what tire size would I run? Thank you in advance.
Old 11-08-13, 06:55 AM
  #340
sm1ke
sm1ke's Avatar
Originally Posted by DeanIS
Hi,
GL with the sale of your wheels. I just received my wheels. They are 19x8.5 ET35 and 19x9.5 ET40. These will be going on my wife's 2010 AWD. Should I be running 235/35/19 and 265/30/19 OR 225/35/19 and 265/30/19. I do not want to run 275 in the rears because I do not want to deal with fender work. Any input would be greatly appreciated.
Dean
If you're dead set on 265 in the rear, I would suggest 225/35 up front and 265/30 in the rear. The difference in rolling diameter between the two is only .24% compared to using 235/35 up front, which is .87%. Not a huge difference, but I would minimize the risk as much as possible.
Please take note that my wheels are 10.5 in the rear with a +43 offset, and I'm running 275/30s. I think your wheels would be less aggressive than mine by about 4-5mm. On my setup, there is no rubbing whatsoever, and my fenders have not been touched yet. I'm lowered on BC coilovers to maybe 1/4 finger gap in the rear. The natural camber is just enough to ensure that if I do hit a bump, the tire doesn't hit the fender. With that said, my fronts are 8 wide with a +37 offset, and have 235/35 mounted on them. They rub on turns and dips at the same 1/4 finger gap, but it's just the fender liner.
What are you using to lower the car, if anything?
Old 11-08-13, 07:27 AM
  #341
DeanIS
DeanIS's Avatar
thank you your reply. I just lowered the car on Tanabe NF springs. Very conservative drop. This is the wife's car so I do not want to go too crazy. Will I be needing an alignment? Been reading about guys with the Fsport springs and not getting an alignment because it's less 1" drop.
Old 11-08-13, 07:37 AM
  #342
sm1ke
sm1ke's Avatar
If it were me, I would get an alignment anyway. Not sure if it's necessary though.
Old 11-08-13, 08:23 AM
  #343
reyoasian
reyoasian's Avatar
what's your front setup?
i'm thinking of 9/10.5 with 235/35 275/30
but having trouble deciding on offset (for flush)
preferably no fender rolling
Old 11-08-13, 09:08 AM
  #344
sm1ke
sm1ke's Avatar
My setup is
19x8 +37, 235/35/19
19x10.5 +43, 275/30/19
Unfortunately the OEM equipment only allows for a little bit of camber correction up front, and none in the rear. Before alignment, fronts were at about -2 degrees, rears were at -2.3 and -2.5 degrees. I was able to get the fronts to -1.5 degrees, and got the toe in the green on all four corners.
The plan is to get the front to around -0.5 degrees and the rear to -1. I should get the look I want after that (flush), provided I don't change my wheels lol. This is going to require rolling at least the rear fenders and some fender work in the front. I probably won't get around to it until the spring though.
With my front wheels at -1.5 degrees camber, i think I would have had to add a 5-8mm spacer to make them flush with the fender.
Old 11-13-13, 06:30 PM
  #345
DeanIS
DeanIS's Avatar
I finally for the wheels/tires installed. I went with 225/35/19 and 265/30/19. I am happy with the rears setup. However, the 225/35/19 on 19x8.5 looks stretched; the edge of the tire does not reach to the of the wheels like the rears. Will 235/35/19 fix the stretched look? Finally, will 235/35/19 and 265/30/19 work on my AWD?
Quick Reply: Staggered setup on AWD ! - The Mother Thread - !
