Staggered setup on AWD ! - The Mother Thread - !
Old 06-09-14, 07:50 PM
  #361
sm1ke
sm1ke's Avatar
Originally Posted by sm1ke
Let me take a couple of pics for reference.
Sorry for the poor quality and lighting.
Height:
Fit:
Rubbing/Damage. The burns are from the fender tab plastic, the cuts are from the tab itself before it was bent back a bit. It still does cut a bit if I hit a dip too fast:
Control arm clearance (18x9.5 +30, your +35 will come closer to the control arm):
Hope that helps.
Also, just some general advice for anyone lowering their car more than 1.5".. Do NOT get the SPC adjustable front balljoints. They simply don't have enough adjustment to make them worth it. Opt for the Figs or Megan Racing arms instead.
Old 06-09-14, 08:53 PM
  #362
dfwjohnd
dfwjohnd's Avatar
fwfwfwfqwfqjoqwjfoqjwfqwijqw
Old 06-09-14, 09:05 PM
  #363
laobo979
laobo979's Avatar
Originally Posted by dfwjohnd
Found a good deal on a used set of wheels-
Fronts: 19x9.5 +22
Rear: 19x10 +25
My Car: '11 is350 on BC's with 12k/10k Springs.
Would this look strange? Rear fenders rolled, would the front need it as well? Also, what size tires would I pair with these? Don't mind a little stretch and negative camber, will I need any Megan arms? If so, front, rear or both?
Thanks.
225/35 F 255/30 R or 235/35 F 265/30 R with the front you'll need roll/slit pull, trim inner linear and relocate the bumper tab. Rear roll/pull if you get the complete rear megan 5 piece they'll fit perfect. The more adjustment you can make the easier the fitment.
Old 06-09-14, 09:06 PM
  #364
RDIS250AWD
RDIS250AWD's Avatar
Remy you'll be fine with 18x9.5 +35 up front. It will be just about flush with camber set to about -0.5 degrees. You can do 235/40 to fill out the wheel gap a bit more, but if you plan on doing fender work (ie. bumper tab relocate and shave away extra metal, heat up and bend back fender liner, and fender roll), you can go all the way to 245/40 easy.
I'm running 245/40s on 18x9.5 +30 wheels all around on my AWD right now. Front fenders rolled slightly, fender liner mostly rubbed away, bumper tab metal bent back a bit. I do rub on heavy dips and sometimes when I turn. Let me take a couple of pics for reference.
thanks for the info and pics bro but will 235 in the front and 255 in the rear throw off my rolling diameter?
Old 06-10-14, 06:14 AM
  #365
sm1ke
sm1ke's Avatar
Yeah, there's a difference of like 2.75%. It's doable though, I've heard the threshold is 3%. Maybe look around and see if anyone's been running that setup for a while?
Old 09-26-14, 11:53 AM
  #366
amw896
amw896's Avatar
Default Please Check!
Hi All,
I'm currently on the 19" F sport Forged rims with the following:
Front: 19"x8" with 225/35ZR19
Rear: 19"x9" with 255/35ZR19
With this set up my rolling diameter is off by about 3.2% (please check my math!) and I'm getting crazy wobbles, and weird shudders.
I'm thinking about changing to either F 225/40zr19 with R 255/35zr19 OR F 225/35zr19 & R 265/30zr19
What is better? Please help!!
Old 09-27-14, 08:56 PM
  #367
sm1ke
sm1ke's Avatar
Originally Posted by amw896
Hi All,
Have you had an alignment done yet? Get the rear toe to as close to zero as possible, it'll eliminate the majority of the wobble, maybe even get rid of it completely.
Old 12-03-14, 09:36 AM
  #368
Scless
Scless's Avatar
Hey guys, I am planning on swapping my Work VS XX for Work Meister 3pc. The Meister specs are 19 x 9 +0 and 19 x 10 + 0. I'm wondering how much work will need to be done to fit these? And should I rebuild them for a square set up?
Old 01-22-15, 07:07 PM
  #369
reyoasian
reyoasian's Avatar
planning to run on stock 18" wheels:
225/40R18 front
255/35R18 rear
rear has -0.06" diameter difference than front
2009 IS250 AWD
Any advice?
Old 01-22-15, 09:56 PM
  #370
manangel
manangel's Avatar
225/40R18 front
255/35R18 rear
2009 IS250 AWD
Any advice?
I am running this setup with F-Sport suspension on 2007 IS250 AWD for a year with no problem so far. As well, seeing 3IS AWD running with the same spec, I'd assume this is a safe setup IMHO.
Old 01-23-15, 06:02 PM
  #371
CJITTY
CJITTY's Avatar
Another update even though I don't have an IS. My 600hL is going on 3 years now running staggered.. No signs of any issues with my CVT AWD transmission..I matched up front and rear sizes to have nearly identical overall diameter of course
255/30/22 on 22x9 front
305/25/22 on 22x10.5 rear
Old 02-18-15, 06:25 PM
  #372
reyoasian
reyoasian's Avatar
Front: 19x8 with 225/35 25.20" diameter
Rear: 19x8.5 with 255/30 25.02" diameter
Is this okay? Rears are 0.18" smaller than the front meaning a 0.72% diameter difference.
Any advice?
Old 03-16-15, 12:46 PM
  #373
Rexus205
Rexus205's Avatar
Hi guys,
Looks like the responses have slowed down because everyone is sick of seeing this thread.
I have a set of rims 19*8 front and 19*9.5 rear
from what has been posted it looks like the best set to roll with would be 235/35/19 front and 265/30/19 rear.
I have also seen 275/30/19 rear.
Any advice on what would be the closest diameter for these mentioned tires.
Thanks!
Old 03-16-15, 07:47 PM
  #374
minato
minato's Avatar
Originally Posted by Rexus205
Hi guys,
Thanks!
Tire Diameter(in) Circ(in) sidewall height (in)Diameter (mm) Circ(mm) sidewallheight (mm)
275/30R19 25.496 80.098 3.248 647.6 2034.5 82.5
235/35R19 25.476 80.036 3.238 647.1 2032.9 82.3
265/30R19 25.260 79.356 3.130 641.6 2015.6 79.5
I attached the CL tyre calculator for reference.
I am running with 275/30R because its closest with 235/35
File Type: xls
Old 04-08-15, 01:48 PM
  #375
Rexus205
Rexus205's Avatar
Thanks Minato
Quick Reply: Staggered setup on AWD ! - The Mother Thread - !
