Staggered setup on AWD ! - The Mother Thread - !
#76
Go here, then go down to "aspect ratio" where it explains it-
http://www.tirerack.com/tires/tirete....jsp?techid=46
#78
Can the staggered gurus please give me advise on offset and tire sizes I am trying to get 19 x 8.5 in the front and 19 x 9.5 rear. What offset should I get and tire sizes to keep the rolling diameter as close to as possible for my awd. I am goign to get work vs-xx.
#79
^^^ Offsets are very subjective, I'll leave that to others to offer "opinions", no right answer.
Regarding tire sizes with rolling diameter as close as possible to being identical:
front 235/35/19
rear 275/30/19
front 235/35/19
rear 275/30/19
#81
Would it be okay if I ran 225/40/18 in fronts, and 225/45/18 in rear?....I believe rims are non staggered..im not sure if rolling diameter is different...planning to use my SC's rims while I preserve my blizzaks for winter...thanks
#89
Thought I'd add some info.
Wheels: 18 x 8 F and 18 x 8.5 R OEM 18s (same offset, don't remember, but really high. 45?)
Tires: Goodyear Eagle F1's 245/35/18 F & R
Miles: 50,000 in two years (yes, 25k per year). Side note, the vehicle has 75k in 3 years. I used to have a nasty commute, but thankfully not anymore.
Issues: None. Gas mileage appears to not have changed when I was running OEM 17s.
Thoughts: Seemed fine at the time until I realized the risks. But while running that setup, I encountered no problems, performed basic maintenance myself and kept up with major services at the dealership.
Then I decided to swap to GT-7s (19 x 8 +43) and TE37s (19 x 8.5 +43) to avoid being staggered. I used a 15mm spacer for the front and 25mm for the rear. Again, those Volks were not staggered and I'm also dropped on BC Racing coilovers.
Now, however, I'm purchasing a new set and going back to staggered. Going to be running 19 x 9.5 +35 F and 19 x 10.5 +35 R. Tire sizes will be 235/35/19 F and 265/30/19 R. Volk set #3, here I come! Time to wait a lifetime.
OEM 18s without spacers
![Name: DSC_4590.jpg
Size: 86.2 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/436428d1501396585-staggered-setup-on-awd-the-mother-thread-dsc_4590.jpg)
TE37s with spacers
TE37s with spacers
![Name: DSC_5335-1.jpg
Size: 99.4 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/436429d1501396585-staggered-setup-on-awd-the-mother-thread-dsc_5335-1.jpg)
#90
I'm thinking about getting a set of the G35 18" sport rims. The front tires are 225/45/18 and the rear tires are 245/40/18. would this even work on my is250 awd? I am a noob at this.
