Staggered setup on AWD ! - The Mother Thread - !
#106
It will not work on AWD..
OEM 18's are
Front: 225/40/18, 18x8, +45mm
Rear: 255/40/18, 18x8.5, +50mm
That is nearly 2" of difference in overall diameter which is not recommended at all for AWD. The only way it'll work is if you purchase all 4 exact same sizes of either Front or Rear.
OEM 18's are
2 Examples of what WILL work on oem 18's:
225/45/18
255/40/18
or
225/40/18
255/35/18
#107
Before you say "No, your wrong", please read again what his question was from the start. He specifically tried to re-ask what Chekmi21 member's question was, "Will the OEM IS250/IS350 18s with the OEM tires size work on AWD?"
The 18" OEM Tires size was quoted from 4tehnguyen
https://www.clublexus.com/forums/is-...our-setup.html
I never said he cannot run staggered on AWD, I said he shouldn't with the 18" OEM Tire size. And I know you can run staggered on AWD, that's what I've been riding for the past 1.5 years..
#108
What is with people always jumping to say No youre wrong, no thats dumb, no thats false.
How about Yes... and this? Yes but that?
What is worse is they dont even bother to read.
#111
hey guys.. I'm a noob on this forum, just wanna figure out what's the best options for wife's new IS250 awd.. want to be a touch aggressive but not streching tires and roll fenders and quarters
is this safe and what size tires should I get?
18X8.5 +35
18X9.5 +35
18X8.5 +35
18X9.5 +35
#112
I'm thinking about getting an ISX50 AWD in the next week or so. I have a set of WORK S1 Meisters (3PC) that I had on my G35 Coupe and I wanna put them on the IS.
Current Set-up:
F: 19 x 9.5 +24 in BFG KDW2 245/35/19
R: 19 x 10.5 +23 in Toyo T1-R 275/35/19
What tire sizes do you recommend?
Current Set-up:
#113
Spoon and xjonmo:
Your best tire combination to go for is 235/35/19 and 275/30/19. Using these two will bring you within .08% difference. You can also opt for 225/35/19 and 265/30/19 which will bring you within .19% difference. Using these setups should allow you a range of wheels from 8.5-9" in the front and 9.5-10" in the front comfortably.
xjonmo, unfortunately with your set of wheels, I'm afraid those will require a bit of fender work to get them in...Following the recommended tire sizes you'll need to stretch a bit too.
#114
Hey guys, i have a set of volks gt-7 in sbc... 19x8.5 +36mm with 245/35 falken tires all around. Would i be able to just leave the fronts alone (maybe roll the fronts a tad and move the bumper screw forward) and run a 10 or 15mm spacers in the rear with no problems? thanks in advance...
I know i'm a newb to the larger rear wheel panels. i'm running 18x9.5 +15 with 255/35 on my evo with no problems at all.
#115
#116
#117
Spoon and xjonmo:
#118
#120
ok guys, i ran it through the tire calculations but just want to double check with the Gurus
diameters wasn't too far apart
19x9.5 +12 215/35
19.10.5 +12 225/35
its gonna be stretched with rolled fenders
thanks
19x9.5 +12 215/35
19.10.5 +12 225/35
thanks
