Installing the rear GFX piece.
Old 09-18-09, 11:39 AM
Kybball#1
Kybball#1's Avatar
Default Installing the rear GFX piece.
Hey CL, I will be installing my full GFX kit tonight. I am wondering a few things. Should I take off the rear bumper and drill the holes or just use double sided tape? Also are there any other places on any of the kit that I should add extra tape. Im very confident with the front and sides, its just the back im worried about. Thanks in adv.
Old 09-18-09, 11:53 AM
Thr3350
Thr3350's Avatar
Search my friend
This should help ...https://www.clublexus.com/forums/is-...ng-bumper.html
Check Post #52
I will be installing mine on saturday but Im going to try and avoid cutting as much as possible.
Old 09-18-09, 11:59 AM
Coconut
Coconut's Avatar
Do it right the first time and take off bumper to drill the holes. If you just tape the lip to the bumper, its not going to sit right since you have to cut the exhaust openings to fit the rear lip. You don't need to add anymore double sided tape.
Old 09-18-09, 01:18 PM
trixxx519
trixxx519's Avatar
i have hks hi power exhaust, will the gfx rear lip be big enough?
and also what is the cutting of the exhaust? in order to fit the lip
Old 09-18-09, 02:16 PM
Initial G
Initial G's Avatar
I did a search and found a thread about installing the gfx rear with the drilling or cutting. Hope it helps out.
https://www.clublexus.com/forums/is-...ng-method.html
Old 09-18-09, 02:22 PM
quang
quang's Avatar
Originally Posted by Initial G
I did a search and found a thread about installing the gfx rear without drilling or cutting. Hope it helps out.
same link Thr3350 posted here earlier
Old 09-18-09, 02:29 PM
Initial G
Initial G's Avatar
I just edited my last post with the correct thread. I copied and pasted the wrong thread. My mistake. Thanks quang for catching my mistake.
Old 09-24-09, 06:14 AM
H-I-M
H-I-M's Avatar
I just used 3m double sided tape. i figured if it could hold a STI spoiler on my carbon fiber trunk at 140 it would work on the IS lip.
Old 09-24-09, 08:51 AM
Thr3350
Thr3350's Avatar
Did you remove the brackets and clips on the inside of the GFX lip?
Old 09-24-09, 09:03 AM
Kybball#1
Kybball#1's Avatar
Yes, you have to in order for it to fit.
Old 09-24-09, 12:00 PM
BoOst3d
BoOst3d's Avatar
I installed mine with just the double side tape it came with, added some extra on the corners, and ripped off the brackets. Its been on for about a year now and nothing but good things.
Old 09-24-09, 12:07 PM
funnie
funnie's Avatar
I agree with coconut! Drill !!! do it right. make sure that sucker stays on. I am sure the 3m tape is strong enough to hold it, but then again its tape.
If u get it done at the dealership, they drill too, do it to it ! GL with everything.
Old 09-24-09, 02:03 PM
juice14
juice14's Avatar
just do it right and follow the instructions one by one. cut te bumper like it sayd it will fit perfectly.
Old 09-24-09, 02:33 PM
All4sho350
All4sho350's Avatar
no need to cut mine fits perfectly over 2 years now i justed used 3m doubled sided molding tape and then some extras on the corners
Old 09-24-09, 08:26 PM
ecr527
ecr527's Avatar
I removed my bumper and cut it when I installed mine. It's a little nerve wracking knowing that if you mess up, your bumper is toast, so make sure to measure twice and cut once. Once you remove the bumper, you'll notice that there are marks on the back of the bumper, so you really can't drill into the wrong spot. Good luck with your install.
Quick Reply: Installing the rear GFX piece.
