IS350 around Track!
Hello guys!
I have decided to make a new thread on the is350 around the track.
As some of you know (thanks to all you cl members that replied =D) I might take my is350 on the track along with the sti and s2000. I wanted to know if anyone experience and took their car on track with/out modifications. Like many of you stated (coil overs, lighter rims, sticker tire, sway, chasis), would these modification allow me to keep up with these track monsters? I know that is350 are heavy but a little lighter than the 335i bmw. I am a amatuer on cars and was wondering how the 335i handles better than the is350 and wanting to know if the the 335i would be able hang with the s2000 or the sti. I know that some people stated that the is350 handles close or better than the 335i with sway bars and springs ,etc. So I was wondering with this theory in mind that if the 335i can hang with these car, shouldn't the is350 with modification also be able to?
Thanks !!
Thanks !!
I'd say its moreso the driver as opposed to the car, which will determine who hangs with who. Some cars definitely have more potential and inspire more confindence around a track, but if anywhere, paper performance means less in that environment. An example: a father/son combo recently brought their stock 98 Neon out to a local autoX for kicks, and posted a faster lap time than my buddies MX-5 and some other regular drivers, while posting less than a second slower than a Porsche Cayman*.
I'd take it out and have fun/learn with it, notice that some seemingly slower cars (drivers) are faster than you, then improve where you can.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
* Other marques: http://www.gws-mbca.org/ax/ax-09/ax09-6.html
Also depends on the track, eg. if your on a small track with lots of tight corners, hairpins and not many straights, those smaller, lighter cars (s2000 and sti) will haul ***, and ud prob have a really tough time keepin up.
But as stated above, it really all depends on the driver.
driver ability being equal and oem-spec-for-spec, on an autocross parking lot pylon course a stock is350 will get owned by the s2k and the sti. the stock suspension is too forgiving at the limit, and unless you disable traction control you'll be electronically handcuffed. that, and the hesitant nature of the "tiptronic" automatic transmission means you'll be spending more time waiting for the transmission to change gears than the actual changing of the gears by the transmission.
given the same assumption, on a high-speed course that emphasizes power/speed more than handling, the is350 might stand a chance, as it's got more power to compensate for its average handling. while the is350 has more useable power at lower engine speeds, the STI would have to stay in boost, while the s2k would have to be in the astronomically-higher revs.
If you start talking modded though, then I think the IS would fair better but I'm not sure how much the slow tranny will hinder, or help, you. Then again if your buddies with STis S2000s, and 335s are also modded then they may end up be just that much better than you... Just go out an have fun. If you lose to them so what? At least you'll be more comfortable than them...
I noticed a great improvement in the handling of the car after I dropped it on Tien springs on put on aftermarket wheels with higher (or lower numerically) offsets. I did a track day event recently and the car handled great. As far as the transmission issue goes, I put it in PWR mode and left it in full automatic. There wasn't a single time where I felt that I wasn't in the right gear or that it was hesitating.
Yeah the paddles are a joke. If you shifted a manual that slow you'd always be out of the power band before you completed your upshift... haha
the IS350 could beat the 335i on a track if the IS350 driver is better than the 335i. but with the same driver the 335i will probably make better times
lower ride height and rear sway bar and the IS handles SOOO much better, so it doesnt take that much to make it a fun car.
^ on a road circuit, only if the 335 kicks into limp-home mode and cuts back power. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
in all seriousness though, driver ability and stock spec-for-spec being equal, the 335 should be a bit faster than the is350. it's much more of a driver's car than the is350.
as far as what a driver's car is, you can come to your own conclusions about that.
