roof spoiler??
hey guys, just have a quick question before i intall my roof spoiler, i was lining it up today, i was wondering, if you guys are installing it right on the roof line?? or on the rear window, if installl on the rear window line, there will be a slight gap, or do you guys install it right on the roof line?? i ono just want to know before i install it, it was a pain taking off the double side tape, does anyone know how to take the double side tape off in a easy manner?
Roof spoiler goes on the rear window. The middle doesn't stick too well, so you really have to add extra mounting tape and press down. Blow dryer and fishing line should eliminate your troubles taking off the spoiler, and goo gone should get rid of the rest of the residue.
Use search, there are many threads on roof spoiler installs.
When I was testing fitting the one I had, I just aligned it to the lines of the rear window. Lucky for me, the fitment for the one I had was right on.
I also attached it by using 3M double sided tape that was industrial strength (red back & holds up to 5lbs). I just taped the top and sides and not the bottom portion of the roof spoiler.
Just spend some time aligning it and it should come out fine. Good luck.
if you have time later, can you take a picture from a slight distance as well. I would like to see how it looks with more of the car in the picture. Thanks. I have the same Matador Red as well. I get so many compliments on the color..
Suggestion on lining up roof spoiler - "test" place it on glass where it should be mounted and tape small paint trays upsidedown under it and small cardboard tabs on the sides so when you peel the tape backing to install it, all you need to do it drop it in place and it lines up perfectly.
Worked like a charm for me....
