Hey guys, have you guys ever experienced any rattles while driving, in the interior around the passenger side door? Is this normal? It rattles, not noticeably but it kinda bugs me. Thanks
I had the door storage compartments rattle a bit. I'm talking about the ones that swing out to open in each of the front doors. I added some 1/8th inch gasket tape to where the pocket panel touches the door panel when closed and that did the trick. The gasket tape you can get at Home depot for cheap, it comes in a roll in different thicknesses, it's like a foam tape with some rubber on top. Not sure if that is your problem but try to firmly press against the storage pocket while driving to see if the rattle goes away.
My driver's door handle area (right hand drive) rattles too, but not always. It's the plastic trim behind the door handle which i felt a bit loose that causes it.
sorry for late response. I just tried taking it appart but didnt, and it went away. Now searching for this I found this thread again. I think this time its from the passenger door
Yes, the dealer knows how to fix these issues. I had a rattle in the driver door. they said they took it apart and replaced a piece of the panel.
The worst was the most annoying rattling that would come from the dash(middle part and by the glove compartment)
Took it to the dealer and the PROBLEM IS SOLVED. Basically, what they did is add more insulation in there to stop the rattling. so far so good!
hmm do u guys get rattling with the silver part of the door handle (not the chrome by the lock) when theres music playing? i know the mirror sometimes rattles, but if i squeeze the handle while music is playing the rattling goes away? anyone have similar rattles?
i fix the rattle through the dealer, they had a tsib for all these dash rattles. some how, the rattle comes in and out, now theres a rattle on my front passenger seat. sounds like a swoosh noise. anyone has this problem?
