Headlight bulbs + fogs
Hey guys.,
I recently purchased a new IS 250 and I'm new on this forum. I tried searching through the forums to see if i can find the answer to my questions, and i kinda did. But now i cant seem to find the thread anymore. Any ways here is my dilemma:
My car is equipped with the HID 4300K headlights. but when the head lights are turned on at night there is a small bulb on the top corner of the projector which illuminates yellowish. I want to change this bulb but I'm not 100% sure what type of bulb it is. My guess was 168 or T10 from what i read.
Second problem is my day time running lights. is it the same bulb as top?
I apologize if this question has already been posted, i tried to search but wasn't 100% sure.
Thank you very much for your time.
correction.
the DRL's are the high beams running at half power. iirc, those are 9005.
the top one in the same housing is a 168 bulb.
if you need help with any other bulbs, check this replacement guide search result @ sylvania.com.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
