Are there drain plugs in trunk?
In my haste, I forgot a bag of ice in my trunk overnight. When I pulled it out the next morning, a small portion of it had melted and the carpet was damp. I pulled off the mat, the pad, the foam with jack, and the spare. There was a half inch of water pooled up at the bottom of the bay that holds the spare. I noticed three black plugs toward the back and pulled one out. Shined a flashlight through it and it appeared to go into a black hole. Some water dripped down into this hole, but nothing appeared wet on the pavement after. Did I just send water to a place I shouldn't have? Maybe the mystery water falls out when you drive? (The rest of the pooled water I wiped up with a towel.)
Yep, those are the plugs I was referring to. Just that no water appeared on the ground after I did a little draining.
topgun129
01-24-10 07:38 PM
PhilipMSPT
10-30-07 03:29 PM
