View Poll Results: What brand of gas do you like most for your IS
Chevron
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
53.33%
Shell
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
40.00%
Sunoco
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
BP
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
13.33%
Exxon/Mobil
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
13.33%
What ever is cheapest
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
6.67%
Any top tier station
0%
Oh no, not another poll - who cares
0%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Favorite Gas for your IS?
#46
You guys are hilarious!! If Crisco spent enough money marketing "cooking oil" as the best fuel available, some of you would swear your car runs better on it.
All automotive gasolines have the exact same DNA but, if it makes you feel better to use one over another - "fill her' up"!!!
#47
red beans and rice.
#48
#49
Can't remember where the cut-off is (maybe sweetwater) but Fort Worth was always 93 octane and Lubbock is 91 territory. I randomly guessed that maybe it had something to do with altitude and the combustion. Have no idea really.
#52
I disagree.
I recently did testings with full tanks of both octanes at multiple different stations/times (probably 3 or 4 each) just to see for myself if there really was a real difference and I DID notice that 93 octane ran smoother than 91, especially at idle. 90 octane was even worse. And no, I did not go to any no name gas stations at any point in my testing.
However, I did NOT notice any real performance difference between any of the octanes, just a smoother idle & engine.
Where does it actually say in the specs from Lexus that the 2IS is a 91 octane specific engine? Really? I would like to see that.
I do know that a car requiring regular unleaded (87 ish octane) will see no benefit from 93 octane, and may actually cause damage to the engine with consistent high octane usage. However on the IS, I think a higher octane super unleaded gas does reap some benefits. That's what I experienced.
And anyways, if one station has 91 & another has 93 for the same, everyone would choose 93 as a no brainer. Why not?
I guess if you live in an area that doesn't have any 93 octane stations, then you are getting the "shaft!"
#56
I disagree.
Try the owners manual.
It's probably on your gas tank lid too but not positive.
It requires 91 octane. There's no chemical reason 92 or 93 would run any "better" on this car, so I suspect you saw a placebo effect.
(I've never even seen 90 octane...just 86, 87, 91, 92, and 93)
#58
The car is programmed for 91 octane fuel. That's the timing it runs. If it detects knock it pulls timing, but it never adds any more than it was programmed for.
Anything higher is completely useless under normal circumstances.
Now, for a forced induction application that's another story since you're going to have no control over engine timing so increased knock resistance can save you from a blown motor. Higher octane, in and of itself, won't, ever, add any power though, because it's not possible for it to do so.
In the case of the poster I was replying to he suggested that 93 somehow produced a better _idle_ than 91 though, which makes even less sense since the car isn't really doing much at idle.
#59
Numbers don't lie... conclusions drawn from them can be drastically wrong though. Like a guy who resets his ECU when he installs an intake and is SURE the difference in how the car drives right after is from the intake, and can show you numbers. But the change is really from the ECU reset, the intake did almost nothing.
It's simply impossible for "brand of gas" that is otherwise the same (octane, ethanol, driven in the same car under the same traffic and driving and road conditions, in the same weather) can produce 20-30% differences in mileage.
There's lots of variables that CAN cause significant mileage differences other than brand of gas though, that I suspect your numbers don't honestly control for.
Go talk to an engineer that actually does this for a living sometime (smpis350 has done so and posted about it)... he'll laugh at you if you try and "scientifically" claim the brand of gas changed your mileage like that.
Gasoline is fungible. In part this means that the base fuel is the same from one brand to another. The differences that are added afterward simply can not make significantly changes to mileage from one tank of gas to another.
Now...drive the car aggressively, in traffic, in certain weather conditions, on certain roads, using a fuel blended with ethanol.... then drive the car passively, without traffic, on different roads, in different weather, using a fuel without ethanol, and you can see drastic mileage changes. None of those things reflects the brand of fuel though.
AFAIK there's no brand that universally avoids ethanol year-round though (but you might find a certain station that doesn't have it in your area)... part of the reason is what was stated, tankers delivering to stations draw fuel from the same sources, and then just put in the brand-specific additive package (which can, in no way, have the sort of impact on mileage folks are claiming).
even with the same brand of gas stations, i do get different mileage but its only 0.5mpg difference
smpis350 isn't only the engr. anything he says isn't the bible.
lol
#60
I'm not "suggesting" it, I'm stating it as a fact.
"The car is programmed for 91 octane fuel"
The car isn't programmed for 91.
" Higher octane, in and of itself, won't, ever, add any power though, because it's not possible for it to do so"
higher octane will give you more power.
..come on. its basic stuff
