would 19x8.5 +29 work?
Old 11-09-09, 08:48 AM
dappy
dappy's Avatar
Default would 19x8.5 +29 work?
I have a Q on wheel offsets. Would 19x8.5 +29 all around work on a staggered IS250 (non-AWD) without any fender mods? I'm currently lowered on Eibach Prokit. Would the wheels appear flush?
Thanks in advance.
Old 11-09-09, 09:02 AM
venZon
venZon's Avatar
They should fit... I'm running a 19x8.5 +35 with 235s no problem and look like i have some room.
The fronts will be sorta flush. The rear will be sunk it.
here is a shot of my car on f-sport springs for reference.
19x9.5 +38 in the rear
Old 11-09-09, 09:09 AM
rule1223
rule1223's Avatar
it will rub for sure, i have 8.5 30 offset front on stock suspension, slightly rub already.
Old 11-09-09, 10:41 AM
venZon
venZon's Avatar
really? What size are your tires?
Old 11-09-09, 11:13 AM
rule1223
rule1223's Avatar
225 front, 35 offset i think will be good. 30 is kinda low.
Old 11-09-09, 11:29 AM
GiantsFan
GiantsFan's Avatar
You will rub the fender Liner on turns, but a heat gun should take care of that.
I'm running 19x8.5 +30 up front... 235/35/19 PS2s and I'm rubbing (on turns)
Old 11-09-09, 11:38 AM
JDub23
JDub23's Avatar
New rims planned already?
I think it should be fine but you'll probably want to run narrower tires to avoid rubbing.
Old 11-09-09, 11:40 AM
dappy
dappy's Avatar
Perhaps?
Thanks for the input guys.
Old 11-09-09, 11:42 AM
mdgrwl
mdgrwl's Avatar
My wife is running a 19x8.5 +30 235 tire (no fender mods) and no rubbing at all. She's running eibach's as well.
I'm running 19x8.2 +22 with a 225 tire (heat gunned like crazy my fender well) and now, no rubbing. But I'm slammed on coils.
You'll be fine
Old 11-09-09, 11:49 AM
dangy
dangy's Avatar
Piece of cake.
Old 11-09-09, 12:19 PM
dappy
dappy's Avatar
You'll be fine
So, running 225/35 series tires on 19x8.5 +29 should be rub free? If I run similar wheel and tire specs in the rear, would it be tucked or "sunk" as VenZon mentioned?
Old 11-09-09, 05:47 PM
AK-47
AK-47's Avatar
I'm running 8.5x19 +22 with 235/35/19, it rub on the mud guard wall, bust using a heatgunned to puch that wall in, then is fine. and I'm on stock high, no drop
Old 11-09-09, 05:57 PM
lexboi250
lexboi250's Avatar
dappy, what do you have in store for us? i'm curious!
Old 11-09-09, 09:14 PM
javyLSU
2IS OG
javyLSU's Avatar
19x8.5 +29, 235/35/19 in the front. You'll need to heat gun the fender lining in a few places, and shave down the tab that connects the fender and the bumper. My next set of front tires will be 225/35/19, I still rub on big dips on the freeway.
Javier
Old 11-09-09, 10:09 PM
dappy
dappy's Avatar
Your wheel and tire specs are a tad more aggressive than the ones I'm planning to use. But, then again you're riding on stock suspension. Seems like heat gun may be necessary.
It all depends if I can get these offsets and tires to "work" (no pun intended). In the meantime, I'll have to tease you.
Would rubbing be less if you switch to the narroweer 225/35/19 tires? BTW, love your 5axis lip and MEs.
Quick Reply: would 19x8.5 +29 work?
