rotate tires on a IS350?
I was planning on doing the maintenance myself this time around and the manual says to rotate the tires. Since we have a staggered setup, do you guys just rotate the front two tires with each other and the back two tires with each other? Or just leave them alone?
you can rotate/switch your tires (the front two tires with each other) depending on which TIRES you are using..I know you can't rotate certain brands due to their design
and you are correct, you shouldn't rotate the tires because it is a staggered setup
to rotate the tires you'll need to dismount the rubber off the rim and swap it left to right/right to left, remount the tires/rebalance and there you're done.
SC400_408
Wheels, Tires & Brakes Forum
04-05-07 10:47 PM
