Vossen/Alignment/Wide Setup/Front Tire Wear Problem..
Khanvict I know you've had more vossen's with streched tire setups than anybody else on the board, so thank you for your insight. I was actually planning to takethe car to an aftermarket type wheel shop next week. I do drive my car somewhat agressively, however, I still think the root of the problem is related to the alignment/camber. Once again the tires do have about 70% tread left of them, so it sucks to dump them this soon. I will probably switch to Nitto's all around now also since the tread on rear tires is shot all around.
I don't really drive my car like a granny either, I've kicked it around a corner more then a few times and had my share of stupidity.. never had a single issue...
Not to mention, I'm sure you have seen my car before... it's not the highest car in the bunch!
Definitely take it to a shop that is more familiar with aftermarket wheels and suspension setups!
It's very unfortunate to say, but the dealers suck when it comes to these things!
VENICE BEACH PART 2??? February is not too far!
Aaron, sounds good buddy... Yeah I've probably had more vossens with stretched tire setups than anyone else on this forum.
wow, I just giggled like a little girl
I almost forgot about that!
Good deal, what do you think about 225/35 in the front?
Guilty as charged! I ordered them from Speed and Truck world in Ft. Lauderdale. The owner is my neighbor so he gives me a "deal". You should definetly run a 225/35 in the front. I have the same size rim as you and I do not rub. Thats after some cutting of my fender liner though.
