does 20" rims rub???
Old 11-19-09, 08:13 AM
MIA_LEX
MIA_LEX's Avatar
After fender modifications you can easily fit 20's. Dont listen to all these guys pushin 18's and 19's.
Old 11-19-09, 08:20 AM
iRock
iRock's Avatar
What u do to fix??? His doesn't look like a 4x4
Old 11-19-09, 09:50 AM
btguerra47
btguerra47's Avatar
i know, idk wut that guy was talkin bout the 4X4 but anyways...i actually took a lighter and got the plastic really soft where the tire was rubbing and re-shaped it so that the plastic was alittle farther back...no rubbing since then lol
Old 11-19-09, 09:59 AM
IXI187IXI
IXI187IXI's Avatar
again it all depends on your tire size and offset.
and yes the red IS does have some wheel gap up front. the rear looks pretty good though.
Old 11-19-09, 11:15 AM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
Wheel/tire gurus feel free to correct me if I'm wrong, but if you adjust your tire sizes for the 20's, then your wheels should fit NO different than a comparable width/offset of a 17/18/19" rim.
To best keep with stock 18" tire sizes, you need a 225/30/20 front and a 255/30/20 rear [assuming you can handle 30 series tires ]
So, get those sizes and then do a width/offset that you know works.
Also, doing this will keep you from having the 4x4 look, as the overall diameter will be almost the same as stock.
Check out 1010tires.com for more offset and tire size calculators.
Old 11-19-09, 11:37 AM
IXI187IXI
IXI187IXI's Avatar
if your overall rolling diameter is the same, your car will still look like its "lifted" even though the overall diameter is the same. thats the illusion you get when you have a bigger wheel and smaller tire.
even if you adjust your tire size correctly, you can still run into issues with the width and offset of the wheel. if your stock wheel is 7" wide and your new wheel is 8.5" wide, you can calc the offset to get the wheel to sit the same inward from the wheel well as a stock wheel (its kind of hard to explain) but you still have a wider rim which is whats going to give you a problem.
Old 11-19-09, 12:46 PM
IS-SV
IS-SV's Avatar
Yes or a simple way to look at it:
With the larger diameter wheel the tire sidewall height is reduced. So the fender gap ends up looking bigger versus the short sidewall of the lower profile tire.
Old 11-19-09, 01:06 PM
dangy
dangy's Avatar
Looks 4x4 to me..
Old 11-19-09, 03:01 PM
MIA_LEX
MIA_LEX's Avatar
For the front get a heat gun and push the fender liner back where the tire is rubbing. Depending how wide of a back tire you choose you will need to cut/or roll the back fenders. Its easy and after all this I can still lower it, just havent.
Old 11-19-09, 03:04 PM
MIA_LEX
MIA_LEX's Avatar
messed that up^^^^ quoted myself haha
Old 11-19-09, 03:25 PM
Phil888
Phil888's Avatar
^^^wth lmao!!
Old 11-19-09, 04:35 PM
sinister2c
sinister2c's Avatar
go big and go low or go home.
Old 12-09-09, 12:24 PM
LPforever
LPforever's Avatar
Yes they do unless your off set is correct jsut took my dubs off after a year......a pain in the anius!
Lutkis
10-29-13 02:01 AM
GreggyG
GX - 1st Gen (2003-2009)
09-23-13 09:42 AM
trickshot4
04-09-13 04:23 AM
joeker
07-15-09 09:55 PM
italiandud
10-30-07 09:17 AM
Quick Reply: does 20" rims rub???
