Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1726
No that was just him thinking of a work around till that issue is fixed, that is all. Besides I looked on online and a FM/AM inline signal booster is just a couple of bucks something like $25 again I do not listen to anything on AM so I does not affect me, but other than the AC values not being correct I love my FlyAudio Navigation and David from carlighttrends.com has always being straight forward with me. He told me that there was a few bugs, and that they where going to be fixed.
So I'll be on the look out for David's email with the next update.
#1727
Like B16da9 has said, I highly doubt that but if they do send out an update and it's not announced here please post your impressions.
#1729
I can tell you that anything out side of an OEM product sometimes does not live up to the expectations. Lots of time an aftermarket parts are not perfect, and I can tell you that IF I needed to hear an AM station and if it takes adding sometime to make it work you better believe I'll add it.
I'll put it to you this way, the FA nav is not perfect, but I personally I'm extremely happy with mine. I knew what I was buying and I was told of its shortcomings. You can always find someone that WILL find something to nitpick about something, like... Oh look the clock is not there, or oh look this button is not the same color, or oh man I wish it had this or that.
Again I can tell you that from what David has told me, FlyAudio is working on making its navigation units as perfect as possible. And again I'm not defining anyone one, all I'm saying is that for the majority of IS owners that do not have an OEM navigation package in their cars, FlyAudio is the only option that we have, and its not a bad option at all. Again I knew what I was buying and I'm fine with its shortcomings, and honestly outside of the AC settings being off so what, it cools as it should and it heats as it should. It has done everything that I was told that it would, and again I thank David for honest with me.
And when the next update rolls out, and the AC values are fixed then In my eyes its worth what I paid for in spades. And if some would asked me if they should get one for their car, hands down I would tell them to go for it!
#1730
CoderDan
I'm eager to see what the update will bring to the table. I'd like an in-dash OEM-looking nav system so I do honestly want to see it get better but right now I just wouldn't feel like I'd be getting my money's worth.
#1732
I think you'll need to get that signal booster, I don't think a software update can fix that.
#1733
AM reception was perfect with my stock unit, and with the first gen Flyaudio I had. So why would it suddenly be a reception issue with the 2nd gen? That tells me it's an issue with the unit itself and not the reception. But I guess for $8 bucks on ebay it's worth a try...
#1734
#1735
Hey guys. Just installed a 7k series I stole off of ebay for 500$. I havent had any issues as of now but I do have some questions.
Did anyone else have an issue getting the upper vents to fit back in correctly? Theres about a quarter inch of lip left at the bottom of the vent that wont go over the nav unit..I know i did everything correct but want to make sure theres not another way to fix it before i start taking everything out to double check.
Where can I get the update for GPS? When I try to open it, it just says "file path does not exist"
And last..My windows were messed to hell when I finished. None of them could be controlled from the drivers panel. So I did the "reset" that I found in another thread and it worked for all the widows but the passenger front door. Any suggestions?
#1736
7k series??
For the vents your gonna have to mess with them in order to get them to fit right, it takes a while. Also be careful not to damage the dash... Alot of guys including myself have took a small piece out of the dash while installing the vents back in place or taking them out... ****ty dashboard.
For the GPS, check the sys text file and see if the path is correct?? Duno
Windows... You discounted the battery? You have to go to each window and roll them up and down a few times. If you see the window button blinking, means it needs to be programed to auto roll up and down.
#1737
7k series??
As for the vents..they are about to drive me nuts! I just cant make room to move them up in order to get them to fit..guess I'll keep playing with them.
I tried the window thing. I did disconnect the battery but individually rolled each window up and down until they reset..the only one that didnt work is the front passenger window..
#1738
kinda sorta but not really discouraged...
Just bought a Flyaudio for my 06, should be delivered next week, and am a little shocked at some of the issues I have read on this gynormus thread... but still does not discourage me enough to write it off... yet. The advantages seem to be worth it as long as they continue to come out with the updates to fix the bugs. I'm assuming (and hoping) it's the second generation. Didn't even know or think to ask. A couple questions, seems most of you installed this yourself, easy to do? Instructions included? Also, if mine is a second generation and not updated, how do I update?
#1739
https://www.clublexus.com/forums/is-...6k-beware.html
If yours is a second gen, hopefully it comes with the first update. We are anticipating a second update to fix the temperature display issue.
#1740
