Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1757
Flyaudio sent me their latest firmware that is supposed to fix the A/C temperature setting range for testing purposes (it's not ready for release yet). They fixed the AC display in other menus, so the black bar on the top of the LCD doesn't show "OFF" anymore and it actually shows the correct temperature as well as fan speed. Also, after starting the car, the Climate menu shows the vent position now (our units currently don't show the vent positions when we start the car unless we change the fan speed). They still need to do more work for displaying the correct temperature range under the "Climate" menu. The range is between 66F-84F instead of 65F-85F and 73F and 82F are repeated as a result of rounding error during C to F conversion. Here are couple of photos:
![](http://i1099.photobucket.com/albums/g393/nimam81/IMG_20120118_142843.jpg)
![Name: IMG_20120118_1428521.jpg
Size: 74.9 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/456511d1501791993-flyaudio-in-dash-multimedia-gps-navigation-system-for-lexus-is250-350-img_20120118_1428521.jpg)
#1758
#1759
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I agree, it would have been nice if they could open the source. then we could enhance the UI.
#1760
NimaM, Please make sure on the way of fixing Fahrenheit they don't inadvertently screw up Celsius again for those of us needing C.
Also, would you ask them to fix the mp3 playback via usb drive so that it works as well as by Ipod?
Also, would you ask them to restore the ability to play movie files (avi/mp4) via the usb drive?
NimaM, what navi software are you using?
Much thanks for working on this with flyaudio!
#1761
I'm using iGo Primo 1.2 and I love it especially at night since all the colors match with the instrument cluster. I have also tested latest version of iGo Primo 2.0, but there isn't much graphical differences and I like Primo 1.2's color themes better.
You're absolutely welcome.
#1762
I will tell them about the temperatures in C. What are the OEM A/C controller's temperature ranges because I can check the Celsius range? One thing I know for sure is the increments are 0.5C and if I remember correctly, the temperature starts either at 18C or 19C. Please confirm the range in Celsius.
I can play mp3 files via the usb (under the DVD menu) with no problem. However, I still haven't figured out how to use the "Mp3" menu. Could you elaborate more on this issue?
As far as the "mp3" on the menu, it's for playback of mp3's stored in the SD card, and that works well until it doesn't. Just like the Gen 1 flyaudios, it's unstable and unreliable to the point where CLT said flyaudio don't recommend using it, even though it's right there on the main menu. So at this point the ipod connector is the ONLY viable mp3 playback method on the flyaudio, even though there's supposed to be at least 3...
#1763
with first generation igo primo crashes at startup because not sufficient ram memory
#1765
My car's currently in storage so can't really check but I asked my friend with an Avalon and his goes from "Max cold" then starts at 18 C to 28 C at 0.5 C intervals, then "Max hot". I presume it's the same with Canadian IS's.
Just playing a few mp3 files via usb is fine, but if there's a lot of mp3's, it doesn't handle them the same way an ipod does. I don't remember exact specifics but IIRC it doesn't keep your last playing position, and doesn't save your playback options such as shuffle in between car on/off's and you'd need to set it each time. I just want to set it once and leave it like an ipod, where it will remember your exact last playing position and settings automatically whenever you turn on the car.
Temp range is correct!
I will let FA know about the mp3 playback bugs when I talk to them.
I also recommend contacting them to let them know of the issues with this unit so that they keep hearing about these issues from many customers. I have given them a lot headaches and if others join it will get better.
#1766
I have a 2006 IS and a 2gen flyaudio unit... Bare in mind that I'm in Belgium....
The unit works good, never had the temp display problem...
But it still has issues, many of wich have been said here already.
First is the lack of playback options on the unit... If you want to view videos you have to either have them on dvd or have an external player, and that is just not ... so good...
I have Igo primo running and also get the out of memory error (been a while now but sometimes it happens) . Also when running the navigation the unit freezes if I get a call and the bluetooth is connected.... The conversation still goes through the unit and when I hang up I need to reboot the unit most of the times, sometimes it just keeps functioning as it should, or I get the out of mem error. Not so good either....
The most important for me is to be able to play anything (or almost) using the usb connector, and this is something flyaudio should/could have implemented from factory... I hope they figure this out...
Also someone said he could get in the service menu of the 2gen unit... I know it involves a code wich I think everyone should have in order to do a hard reset on the unit instead of just rebooting the unit... So if anyone knows how to get in this menu, please tell us...
Thnx
Thnx
#1767
When I was in China, I was ready to buy this unit, but it was only 600 USD cheaper than what can be bought here. And given the amount they're asking, I really expect continuous support and have last gen issues fixed and whatnot.
#1768
Mine restarted itself twice the first day I installed it, but it never happened again.
As for the navigation, I experienced the same until I started using a different SD card and iGo8. I think the problem could be the SD card that came with Flyaudio unit. It's a cheap one.
