Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1876
To change them do you just pull hard on the yellow wire. If so, does it comes out with the pin from the main harness. Then do you just push it hard into the flyaudio socket?
I've just got my flyaudio unit today and haven't got the old head unit out yet.
Also, does anyone know what the following cable are for:
The one labelled "lin" - black RCA type connector.
The BAT+/-, ACC, BRAKE, BACK connectors
The CAR SPEED one.
Should these be hooking up anywhere?
I must say the instructions are next to useless!
The CAR SPEED one.
If you connect the wire labeled "Brake" to the emergency brake, then you will not be able to watch DVDs while driving.
#1877
Hey guys,
I just bought this unit and all of a sudden my GPS option doesn't work. The nav system will run,it's like the maps won't load. It just looks like my car is driving around on a pink background.
I'm getting fed up with the Odyssey system....does anyone have any advice on how I can get a new GPS system to run on my FlyAudio nav system.
PM me with any details or help you can provide!
Thanks!!
Thanks!!
#1879
Hey guys,
Thanks!!
Thanks!!
#1880
I was wondering if anyone has encountered this problem. My iPod steering wheel volume works but the song selection will not work with the steering wheel controls. I read a few posts ago about that the wrong part of the harness maybe plugged into the unit? Does anyone else have more info on this or maybe a picture to see what I am doing wrong.
#1881
I'm just in the process of installing my flyaudio unit, but I can't for the life of me get that yellow wire out of the factory head unit. I guess there's a technique to this that I'm not aware of.
Do you have to do anything with the plastic strip on top of the connector that looks like it should be able to open up? If so, how do you open it up!
I'm keen to get everything back in without hopefully having to pull it all out again!
One annoying this also, when pulling the vents out the front came of the vents unit and the little plastic strip with holes in it that move all the blades of the vent must have popped off. It seems to be nowhere to be found!
#1884
I have some of those, what do you do with them?!
I can't work out the technique to get at the pin, do you push it out from the front or pull it from the back? Also do you need to do anything with the plastic strip on the top of the block?
#1885
omg i just realized the fly audio i ordered may not be the 2nd gen
http://stores.caraudioproshop.com/-s...350/Detail.bok
do they still sell first gen fly audios?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#1886
From what David has told me in the past there is a lot of first gen units floating around and you see them aggressively priced so they can sale them. He told me that since he is FlyAudio's Florida Sales rep basically FlyAudio direct he is the only source for a true Second Generation units.
I could have saved a little bit, but I didn't think it was worth the savings if something goes wrong later down the line. David has proven himself here with us on CL and continues to do so even though he is no longer a vendor here.
Put it this way when ever I needed help with my unit, he was just a phone call away and never let me down.
Panda good luck, keep us posted
#1887
Yes I would have definitely bought it from CLT if i lived in the US but unfortunately I live in Canada and the border taxed would have killed the deal
I emailed them asking if its the 2nd gen they shipped me... i hope i hear the right answer...
but since they wrote on their website that the unit use a dual core processor, does that mean it is 2nd gen? i think i read many many pages back that the 2nd gen comes with a dual core while the 1st doesnt? and it does say it supports phone book... isn't that a 2nd gen feature?
#1888
#1889
I think it's the right one, panda... I think that's the right model number at least. The first gen was E8039-NAVI or something like that.
If you want, ask them if the lower right button next to the screen says "AV IN" or "CARD". First gen says AV IN and Second gen says CARD.
#1890
So the distributor i bought it from got back to me they said: "All units sold in Canada are first generation for Navi-2 (2009-2011) and 2nd generation for Navi-1 (2006-2008) although they are both come with the same latest firmware. Features are the same except for the 2nd generation they moved the cooling fan to the top."
Since i'm a 2009 guess i'm out of luck both ways.. but if the features are the same then i don't mind. What alarms me is i remember someone on this forum who also got the unit for his 2009 did not get the new features. Guess I have to wait until i find out.
