Old 01-07-15, 01:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
Old 03-19-12, 04:22 PM
  #1951
NimaM
NimaM's Avatar
Originally Posted by MikeyK02
i am a few days away from buying this product....anyone wanna point in in the right direction for install?
someone said it's easy as pie....however I've never made pie :P
Here is a DIY and it helped me a lot when I was installing mine. You just have to be super careful when you take out the center vents so you don't scratch your dash. There is a youtube video that shows hot to take it out:
https://www.clublexus.com/forums/is-...6k-beware.html
Old 03-19-12, 04:34 PM
  #1952
MikeyK02
MikeyK02's Avatar
gat damn I love this site
thank you!
Old 03-20-12, 10:16 AM
  #1953
otrovago
otrovago's Avatar
I used the install PDF that I received from David over at carlighttrends.com along with the DIY. It really is easy JUST BE CAREFUL when working around your dash board.
Old 03-20-12, 11:57 AM
  #1954
IceIridium
IceIridium's Avatar
Woohooo my AM radio is fixed!
Got it done last night just in time to tune in to TEAM radio and hear the Canucks lose to Minny.... :-\
Old 03-20-12, 07:10 PM
  #1955
2jzism
2jzism's Avatar
Big difference right!!
Old 03-21-12, 10:01 AM
  #1956
otrovago
otrovago's Avatar
I've looked at a couple of back up camera's on ebay, does it matter what type of back up camera I get or is there a specific type that I need?
Old 03-21-12, 02:29 PM
  #1957
IS250AUS
IS250AUS's Avatar
What did you do to fix it? I moved my yellow power antenna wire and it made no difference at all My reception is dreadful!
The curious thing is, from my understanding the Flyaudio HU doesn't have a radio, it re-uses the stock radio. However, the stock radio is diverted through the Flyaudio. My stock radio and reception was 100% perfect.
I also just found out that my IPhone cable won't charge my phone. Several people above have also mentioned this issue. How is this fixed? (my firmware was updated 2 weeks ago)
Old 03-21-12, 02:39 PM
  #1958
CarbonDtls
CarbonDtls's Avatar
I'm thinking you moved the wrong wire or to the wrong pin in the harness, cause I did it and it worked perfectly.
Old 03-21-12, 07:27 PM
  #1959
Jarlaxle
Jarlaxle's Avatar
Is there a way to tell what latest version of firmware in the unit. I tried the last one I could find but the password in the txt doc was not accepted.
Old 03-22-12, 12:07 AM
  #1960
IS250AUS
IS250AUS's Avatar
Maybe i have? I pulled the yellow wire out of the FA harness, and fitted it to the plug that plugs into the radio on the bottom (3 pins along). Does this sound right?
Old 03-22-12, 01:11 AM
  #1961
ISBU
ISBU's Avatar
You pulled the wrong wire. Here is the pic. That wire could be the fix for your ipod not charging.
https://www.clublexus.com/forums/att...dio-am-fix.jpg
Old 03-22-12, 12:01 PM
  #1962
otrovago
otrovago's Avatar
How can I change the start up logo?
Old 03-22-12, 12:23 PM
  #1963
NimaM
NimaM's Avatar
1) go to FlyAudio website.
2) download the Logo Tool program and instructions
3) Follow the instructions to change the logo!
Old 03-22-12, 03:07 PM
  #1964
IceIridium
IceIridium's Avatar
I pestered CLT and Flyaudio until they sent me a new harness.
Is yours Gen 1 or 2? I've only heard of 2 units that had the ipod charging problem, both Gen 1, and both AFAIK never had a solution for. If yours is a Gen 2 (from your radio problem I assume it is) then yours would be the first Gen 2 I've heard of that has that problem so far...
Old 03-22-12, 03:09 PM
  #1965
IS250AUS
IS250AUS's Avatar
I will pull it out on the weekend to triple check the connections (again)
If the centre plug pictured (which has the relocated yellow wire fitted) plugs into the bottom radio plug, that's what i have done.
Quick Reply: FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
