Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1996
This is for anyone whose iPod tracks aren't changing with the steering wheel controls. I was able to change everything else such as the volume and radio stations with the steering wheel just not the iPod tracks I used the help of this thread about this exact problem and pulled out the flyaudio today. I was able to fix it so now my iPod can change tracks via the steering wheel controls. I took some pics to help out (the pics are from the passenger side looking down at the unit). The way mine was installed was incorrectly with 3 plugs going into the cd changer. The plug closest to the passenger seat needs to actually connect to the flyaudio harness not the CD changer. I have attached 3 pictures. One shows the harness plugged in the CD changer incorrectly, the second shows the empty flyaudio harness space where the connector from the CD changer needs to go, and the third picture shows the connector correctly installed into the flyaudio harness. Hope this helps anyone else with this problem. Sorry about the large pics, not sure how to make them smaller from my iPad.
#1997
JoeyKool good job, I will have to do that for mine.
Does anyone notice lets say your on the main menu screen and you use the temp up and down buttons and put the temp to lets say 72 degrees and then go to the actual climate screen the temp is actually 73 degrees?
Its like always 1 degree higher and I have the updated BIOS.
#2000
I got first gen fly audio.. iam getting blank screen every time i put in a sd card. and load gps or mp3. or its not reading my sd card..
I formatted the card fat32 but still get the same problem
any helpz!
any helpz!
#2004
Probably filled with bugs and problems until you get a software update that fixes them but adds other bugs and problems and then when you're clammering for another update they go and release a newer model with other bugs and problems and needing the users to find a fix themselves all the while telling those who bought the first one to go eff yourself. Yeah.
#2005
Yes.
I'm just wondering how an Android OS would work on a head unit??
#2006
When I plug in my iPod via the aux input using an RCA to 3.5mm cable, or when I plug in a Bluetooth gateway to the aux input, the sound quality is really really bad. Any workarounds to fix this?
#2008
Guys,
I just got Fly Audio "P0S" system installed and I feel, I've been violated ! I was happy with it until I drove 15miles from the installer and statrted noticing problems'
1, Someone called and I could hear them thru BT but they couldnt hear me.
2. Driving thru the hills my FM reception was basically non existence . At this point I was begining to boil .
3. Got home the system buttons werent working or refused to take commands i.e. wouldnt switch from climate control to Nav!
4.I took my kids out to show off system during dinner run, as I was driving listening to IPOD ( Thank Heavens that works from the steering wheel ) the system for no apparent reason reboots and swithes to fm unbearable reception!
I came home and started reading the trends here and got a fewer answers but Im totally mad about dropping almost 2,000 dollars for this sh....t.
Now Question....
Apart from the fan being on top in 2nd gen units are there any otherways to tell if I got a 2nd gen of 1st ? Since i didnt install myself I have no way of knowing. The manual is very generic in my opinion .
Why cant FA just post updated wares without going thru the 3rd part vendors . Support should be accesible to all. I DONT HAVE TO EMAIL THEM FOR IT .
I have a IS 2006 - Thanks !
Now Question....
#2009
Guys,
Now Question....
Now Question....
yep this is exactly how i feel. I have yet to write a review on it but when i do it will be about 90% negative feedback. i feel most people who praise this system are salesman for fly audio, I cannot believe anyone can be remotely satisfied with this system after dropping 1.5k in this.
#2010
Hi Panda,
I read all your comments and felt sorry after they convinced you to order a unit and u got a 1st generation . I hope you are at least fixing some of the issues already?
Question - Does this system have a compatible XM/sirius radio system ?
