Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#2026
Question for those using iGo Primo: Does it give you POI search result with direction arrows?
I'm using iGo8 and it doesn't, just a hard list and that annoys me because my handheld Garmin uses arrows and it's so handy:
Example:
![Name: 6352.jpg
Size: 24.0 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/456517d1501791993-flyaudio-in-dash-multimedia-gps-navigation-system-for-lexus-is250-350-6352.jpg)
So if Primo does that then I'll consider upgrading....
Example:
![Name: 6352.jpg
#2027
Well, apparently my MicroSD slot isn't working... i have bought a new SD card yet the system refuse to read it... is there anyway to fix this? or is there a way to install the navigation system without using SD?
#2030
Hi everybody! I'am a happpy owner of es350 2008y. Bought it couple days before. And it has flyaudio e8041 allready installed. I readed all this forum. And I think my flyaidio is 2gen. And now I have all problems discussed there.
1. Climat - Celsius temp, works with a lot of mistakes,
2. Radio fm shows around 80 MHz, but really plays frequencys from 100-...
3. Wheel buttons do not work with iPod and MP3. Only volume works.
So now I have next ideas:
1. Bios upgrade.
2. Check all wires to fix buttons.
3. Change yellow wire place.
So please help, is my plan wrong or right? Can it helps me?
Sorry for bad English...
1. Bios upgrade.
#2031
1. Bios upgrade.
1. Bios upgrade.
#2033
1. Bios upgrade.
1. Bios upgrade.
The climate and FM radio display issues should be fixed by software, assuming Flyaudio has one released for your generation unit.
#2034
#2035
So everything work other then the SD reader? honestly i don't care about the Navigation much since i like garmin more...however, if there's a way to fix this problem i'm all about it.
#2037
In the amount of responses after this question, I saw nothing but the incorrect answer. I have a second generation unit and it WILL play AVI files (no MP4 for some reason) from a USB drive. The drive must be FAT32. Just go to the DVD section, select USB mode, then click on "Folder" and find the folder that contains the videos. Once there, click on "File" and it should display the videos.
One other note, I have iGo Primo 2 working with 3D terrain and buildings. The movement is comparable (in "smoothness") to a Garmin 3700 series.
#2039
#2040
Mine's the Gen 2. Would you mind terribly to take a camera shot of the POI list screen with the arrows? Not that I don't believe you but I just want to make sure it shows the right amount of info I'm looking for. Thanks again!
