Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#2192
I saw this post yesterday:
https://www.clublexus.com/forums/is-...pter-a2dp.html
And I was wondering if anybody tried to sync an Android phone with two devices at the same time.
According to the post, the device connects to the ipod interface and connect to the phone via bluetooth. it works with the wheel control to skip songs.
However, I wanted to know if i can connect my phone to the FlyAudio for phone calls and connect my phone to the other bluetooth to stream audio.
and have both connected at the same time.
The unit that connects to the ipod interface and have bluetooth is ML D-100 or music link D100.
i found on ebay for about $40 and I will give it a try. But i wanted to check first if somebody had done that before.
#2195
Hi to all, I've discovered a problem. Reading the post 1996 I changed my configuration to be able to change iPod tracks from my steering wheel, but now Aux in function doesn't work anymore...If you push the button Aux-CDChanger the unit only switch to cd changer and no more in Aux in, If I revert to the original connections, Aux and cdchanger works... anyone has this issue?
A last question, there is a way to see/open pictures from USB? When I go in DVD menu and I select USB mode I can see folder inside my drive, but only movie files, any other file type isn't showed..... My unit is 2nd gen., How can I see images?
#2196
#2197
you can stream bluetooth from iphone/ipod through ipod connector adapter ,dunno if this counts
#2198
But If I leave the stock connections, I lose only the possibility of changing iPod tracks from my steering wheel? Because I often use Aux to connect my phone or mp3...
#2199
Hi everybody.
I'm a new one on the forum and going to install iGo on FlyAudio in IS220.
Maybe, somebody can help me with detailed instructions and links to downaload iGo primo?
Torrent link on PP is the best.
I have iGo primo for android but don't have iGo for WinCE and right sys file.
Thank you in advance.
#2201
#2202
Thanks for your replies NimaM, What can U tell me about this question? Thank you, Luke.
#2203
saturnluke, unfortunately I don't have an answer to your question because I got so fed up with FlyAudio that I got rid of it. So, I cannot test opening photos on FA for you. I never tried opening image files, but you should be able to see mp3 and avi files at least. Maybe you can ask other FlyAudio owners to answer your question.
Nima
Nima
#2204
Has anyone tried using the 30-pin dock-to-lightning adapter and the iPhone 5 yet? What were your results? Holding off on the iPhone 5 until I get a handle on whether or not it'll play nice with my FA navi...
#2205
Hi everybody.
All of the other sites I searched on were a waste of time....links were all bad! Do it ASAP though. I think the links go bad over time.
