Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#2326
You formatted the SD card? Why?
Did you backup everything before hand? Like the D2280 folder and config file?
In the config file, it specifies where certain files are, such as your themes, and navigation.
Lucky for you, this should be an easy fix. Just go to the thread linked below and go to my Mediafire link and download the new D2280 folder and place it on your SD card.
https://www.clublexus.com/forums/is-...tant-info.html
yea I formatted because I assumed files where corrupt
will do as you have said and report back
#2328
#2330
Hey minato,
I have Odyssey GPS software which works pretty well on the 1st Gen unit. I like this software but I would like to try iGo or something else. Here is a link for you to for the Odyssey.
https://www.dropbox.com/s/c0biagr10fk2yqk/Odyssey.zip
Let me know if it works.
#2332
the Gen1 and Gen2 Units are not that far apart. Since the nav software runs off the SD card, make sure you have the right file path or the SD card is formatted to the correct version. If you formatted it make sure the software is sill available on the SD card
#2333
Hey minato,
this was what I did - unzipped file and placed in usb, (no other files in usb)
got same results
the microsd card is formatted to fat32 , is this the right format for flyaudio?
I have 2 new sdcards I tried ,still not working
it seems the unit itself is not seeing the card because I can't browse through the sd card.
#2334
I remember back when this all first started I had a copy of igo 8 and it never worked correctly, I ended up just buying the legit copy from naviextras and NEVER had any problems and since it was a legit licensed software I was able to upgrade when newer versions came out. I just check the naviextras site and its only $64.95 a small price to pay for a full and working iGo software.
JMHO
JMHO
#2335
JMHO
JMHO
I think my problem now is the system does not read the micro sd card as I cannot browse files from the flyaudio unit
sucks now as I have to use my phone as gps
#2336
So the file I posted was the one I pulled right from the SD card I use in my unit. It's late right now and my car is perked pretty far so I'll check the path and send it to you tomorrow.
Do you have a copy of iGo I can try too?
#2338
Hi everyone, I have recently purchase FlyAudio second generation unit. The navigation program Odyssey says it's expired and prompt me to restart every couple minutes. I tried every link to iGO8 and iGO Primo from navitotal but non of them actually launches at all.... And I have already tried changing app path and resolutions.. Can anyone help me please? Thanks in advance!
#2339
Just like to answer my own question..... Nothing could be loaded because I was using a Mac in preparation of files. When I use Windows 7 to do the same thing, it just works....
