Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#2371
#2372
Hey guys.. I am wondering what's the wire color that needs to be connected at the back of the unit for AUX to work? Are we suppose to connect some cable from the arm rest aux unit to the fly audio? Please help!
#2376
Has anyone experienced this issue? (Didn't browse through the whole thread)
I've had the unit installed about about 5 years and generally haven't had many problems but just recently I encountered a pretty significant one...
When I start my car, the defrost button blinks and when I push any of the other climate control buttons, they do not respond. After about a minute, the defrost button stops blinking and I regain climate controls but when I put on the heat / AC, nothing comes out of the top vents, only the bottom vents work. (Front defrost vents still work)
It wasn't a big problem during the winter since I usually only use heat from the bottom vents but now that the weather is warming up, I will need the top vents for AC.
I checked all of the connections and everything looks fine so I am at a loss....hoping to not have to bail on the FlyAudio unit and go back to the factory head unit.
#2377
Does anyone have solution for it..
Rashid khanra60@hotmail.com
#2378
Only problem with FLY AUDIO GPS system is that when it goes hay wire there is no support. Like my GPS hs gotten so slow and get stuck that I get to my destination and it is still sitting on the starting point, and there is no help available. I am trying to contact the original buyer no reply. have no idea where to contact for help. Also the tire pressure indicator not showing the tire presrure ( never dis to begin with) and the temp control on the NAV screen is locked. I should have spend a little more money and bought LEXUS OEM and be done with it.
#2380
#2381
Just got an email: http://flyaudio.us/forum/16-download...039-a-e8041#42
#2382
Here you go: http://flyaudio.us/forum/16-download...pdate-software I can't try it yet because the bosslady just took the car.
#2383
Summer days are getting hot now and I have to blast my AC on High just to cool down lol. I brought it to the lexus dealership and they said nothing wrong with the fuses nor does any code pop up.
See my thread here
https://www.clublexus.com/forums/is-...ront-vent.html
Have you tried swapping back to the OEM unit to see if the problem is fixed? If it does fixes it then maybe there's something wrong with the hardware that is present on both fly audio and OEM unit? If that's the case then I guess i need to buy a new unit...
Please let me know if you found a resolution.
