Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#601
I'm not sure I understand you... When you turn your A/C all the way towards cold, that's when you say it maxes out at 64? Because that's what happenens (and has always happened) in mine. If you turn it all the way down (cold) it just goes into 'HI' mode and the fan blows on max with the A/C on.
Javier
Javier
The temperature range I can choose on my flyaudio according to the display is 34 F to 62 F. Below that it goes into "Lo" mode. Above that it goes into "Hi" mode. While I can certainly understand not needing to go below 32 F (freezing mark!) I don't get why it stops at 62, which is barely room temperature. But the other issue is the fact the temperature is not reading right in the first place. Anything above 45 F I can really feel the heater coming on.
#604
But just in case, is there a way to check what bios version I'm running?
tia.
#605
there is a "how to" video outlining all the steps and processes for updating BIOS and what to look for here:
http://flyaudio.us/forum/16-download...-e8039-a-e8041
This might not be your solution, but its is definitely and option to try since it will not hurt anything by re-updating. When I got my system, my BIOS updates weren't fully functional as well and had to re-install it a few time to get it finally to take.
Just make sure you have a Windows PC, Mac's with windows on it DO NOT WORK. I found this all out the hard way. If it still doesn't work after this, I would suggest returning it and exchanging. You just might have a lemon.
#606
I just got mine installed today and mine also maxes out at 62 then just goes to high. but as for the temp itself its hot. but i was messing around with the unit and if you go into Menu>Info>TMPS>there is a option for temp. now i didn't attempt to change it yet. I will try and let you know what happens.
now i have one more question. is the unit suppose to play burnt dvd's ? Cuz when i try to play burn dvd's with the .avi format it only plays the sounds but no image. is this right or my unit has an issue?
Going back to the temperature question for a moment... Sorry but it's bugging me... I found out today my temp maxes out at 64 and then it just goes into "hi" mode. That can't be right, that's only 17.8 deg C! Strange that none of you have this issue... Any theories from the software gurus as to why? Something I can change in the windows CE o/s?
Need help plz!!
Need help plz!!
#609
I got a lot of PM's about the camera I got for my flyaudio.
I went though my old ebay history and found the current listing: 220579622668.
But remember a couple of things: You need to cut a square hole in between the license plate lights and you need to mount at a slight angle for it to view straight. It's a lot more work than mounting a conventional camera held on by a mounting bracket. Don't say I didn't warn you!
#610
Has anyone tried to use a license plate camera?? like this one ??
http://cgi.ebay.com/ebaymotors/BOYO-...ht_4566wt_1088
#611
Yet another issue that came up for me... lol
I just got a new Ipod nano (newest gen) to play mp3's on the flyaudio. I was told the flyaudio charges the Ipod too so I can leave the Ipod in the car constantly. It was playing without problems for a few days, then it stopped. I checked the Ipod, and the battery was drained.
Anybody else with problems charging an Ipod with the flyaudio? Anything else I need to do on the flyaudio besides the "ipod on" in the settings?
tia ... again.
tia ... again.
#613
2IS OG
tia ... again.
tia ... again.
Javier
#615
Just got mine put in, with backup camera and the whole kit.
I can confirm the temperature bug. I get 34 to 63 or some such as my range. It seems to affect Canadian IS owners only. I assume it will be addressed in the next update.
Until then, it seems that it's about twice the value in celsius being displayed. So leave mine at 46, which is about 23C.
