Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#856
Great find, thanks for the info!
#857
Try recalibrating the screen and see if that corrects the issue. Here is the procedure:
Turn the car off, then hold your finger in the middle of the FlyAudio screen. Start the car and there will be a + sign that appears in the top left hand corner of the screen, tap that, it will move to a different part of the screen, tap the + sign again, and then let the system restart. That usually fixes those kinds of bugs.
#858
^Let FlyAudio know!!! Post in this thread to let the engineers at FlyAudio know how you feel.
Javier
Javier
#861
"Cold Start GPS" makes the GPS search for satellites from scratch every time instead of "remembering" which satellites were in view when the system was turned off. You'd normally want to keep that off unless you're troubleshooting a problem with the system.
Javier
Javier
#862
I do have the problem with IGO being 1 hour slower, have to go into the GPS time menu to uncheck and check the box again then it will add the hour back.
if I repeatedly cycle the power then it seems to keep its time. But I waited overnight and it's 1 hour off again.
Hopefully turning off the cold start fixes it, but seem like a bug in IGO.
I tried to not use auto correction to time zone and set mine to Los Angeles but it didn't seem to remember the timezone. also.. I did press Exit on the application a few times so I know the program exited properly.
#864
right now I am trying something called
[timezone]
sync_os_timezone=0
reset_os_timezone=0
then I plan to not use the auto correct based on location, hopefully it keeps it's LAX timezone. Because this is not a portable GPS and I am not driving out of state at such speed. My theory is that the timezone on the flyaudio OS is set to GMT 0 and that's what Igo is picking up
#866
I thought it might be the case but I don't see anything about daylight savings on mine.
[timezone]
sync_os_timezone=0
reset_os_timezone=0
[timezone]
sync_os_timezone=0
reset_os_timezone=0
I tested this fix and it stays at Pacific time zone now. I am not using auto correction at all (second check box)
#867
here is some explaination of microSD card speed and classes.
I just got the $10 Sandisk 2GB now but looking into faster speed.
The reader from the flyaudio unit may not handle the full speed though so faster cards could be a waste of money.
http://zedomax.com/blog/2010/04/19/f...d-card-review/
Which cards are you guys using?
#868
The screen will not go black. Nothing will change on the screen when you put the car in reverse if you do not have a backup camera.
You need to get the updated harness from for the US based cars from FlyAudio (US based company. www.flyaudio.us). The airbag light will remain on until you switch the harness.
I have tried to contact www.flyaudio.us but has not get any response,
So I'll take and modify the cable harness. There is a 14 pin connector with only nine pins in, (same as the one on the original front). I wonder how the connector looks like on yours harness?
Top row from right on the back of the contact I have the following cables:
Black, Green/Yellow, Empty, Empty, Yellow/Black, Yellow, Empty
Bottom row from right:
Green, Pink, Empty, Red/Black, Red, Blue/White, Empty
I had been really grateful if someone could help myself with this, maybe someone knows where all the cables go?
While I write I can take this opportunity to ask what the difference is on the Dest and Navi buttons on the unit?
Thanks / Olle
