Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1111
just found another problem... im not getting much luck with this, the igo8 software i use
now it shows an error message,
"Previous instance of iGO 8 has not finished exiting yet. Please try again in a few seconds or soft-reset your device"
i have waited for an hr, format and reload all original files back to the sd card and it still doesnt work, anyone has a solution?
thanks
thanks
#1112
thanks
thanks
#1113
i had the same problem of igo 8 doing that to me as well..
I made a list of what I did to make it work without the old software..
1. remove sd card
2. press setup
3. press next
4. press reset
5. start gps software (press gps)
6. press menu
7. plug sd card back in
8. open gps software (press gps)
9. click ok when asked to reset
1. remove sd card
2. press setup
3. press next
4. press reset
6. press menu
#1114
2IS OG
thanks
thanks
Javier
#1115
2IS OG
Members - I've gotten several PMs requesting a link to the iGO software. Please be aware that software piracy (either through public posts or private messages) is against the Club Lexus Terms of Service and is not permitted. Please restrict the discussion to "how to", not "where can I download." Thanks for your understanding.
Javier
#1118
BIG thanks guys
now the software is loading again,
but i realised i lost my option to select the voice warning when driving over the limit and speed cameras alert.
also it can not find my gps receive... sigh...
#1119
actually i just got everything working just as it was before
but im starting to wonder if i need to update the bio in order to get the gps running at 800x480?
also when you guy connect the usb to your laptop, does it show up as a drive?
mine does nothing
mine does nothing
#1120
for who has installed the bluetooth mic on the top dashboard:
where did you put the cable (the path) and how do you put it?
the frame along windows, must be taken off or not?
see the picture for a better understanding of what i mean
thank you
thank you
