Last edit by: IB Advertising
Browse all: Interior
- How to Install a Navigation System
Step by step instructions for do-it-yourself repairs
FlyAudio In-Dash Multimedia GPS Navigation System for Lexus IS250/350
#1233
Hi there,
I am just wondering if anyone knows what this connector is for. I have finished installing the Flyaudio system but can't figure out what this connector is for or what it plugs into. Is this for an optional TPMS? Also, on my system it is wired into the main harness. Any help would be appreciated! Thanks!
#1234
Theres only one way to do it. Play music in sd card. I don't recommend it because it lags your gps a lot.
#1235
New backup camera install ended in complete failure! two major problems...the plug that came with the backup camera is rca, the flyaudio plug...svideo. Now the second major problem, one of the nut that holds down the carbon fiber panel was over torque so when I was trying to loosen it the thing that keeps it from moving came loose too...now I will need to find a way to loosen it. Anybody have any suggestion? Or I might have to find someone to split the nut. For the rca plug problem...I ordered a rca to svideo plug. Hope thats going to work...if not I will probably need to find a backup camera with a svideo plug. Still...the main problem is the panel...
#1236
#1237
Damn thats not good news
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#1238
#1241
Hi there,
#1243
My car must hate me by now. ..took everything out over the weekend, reran everything... Installed the new camera...tested everything and put everything back on the camera worked for a while then it stopped working after I turned off my car. Took everything off again and examined everything...worked again then it stopped working again! Took panel off and tested the voltage with multimeter and checked connection, even used tried external 12v power...still dead...sigh. I think I will need to take it apart again and test the camera somewhere else and see if its bad. Sigh
#1244
#1245
