P/S Power Steering out?
#64
I had aftermarket HID in my stock halogen headlights. They are from xenondepot. I had the issue where my P/S went out and it was the P/S ECU, but did not did what the OP says it did, which is violently change the steering direction. I was out of warranty so needless to say, it was not cheap to fix.
#66
Same problem, same error code. My HID's are also from xenon depot. My power steering went out about a day ago...no violent shaking.
I've had my HID's for over 100k miles also.
#68
Former Sponsor
x2mkx: Under what name was your kit purchased? If your vehicle has over 100000 miles on it the failure could be completely unrelated to the HID kit. Our ballasts have EMI shielding so I don't see how they would interfere with anything to do with your power steering.
Steve
Steve
#69
This has nothing to do with heat. My kit is nowhere near any ecu or components. Last night pulling into my driveway the car loses power steering when turning left only.
- Happens with all aftermarket HID kits
- Doesnt have anything to do with heat
Previous poster hit the nail on the head, the ballasts are interfering with power steering commands/functions.
I dont really want to go back to those **** yellow oem lights...
Will relay harness fix this?
UPDATE:
Seems having a harness alone doesnt solve the issue. Some people experienced success using a warning canceller + relay harness:
UPDATE:
#70
FIXED!
Problem was my 3 year old battery. Just bought the car less than a year ago. Coincidentally there was a fart smell inside of my car and when standing next to it as well. Lifted the hood, lo and behold there was the battery squirtin and steaming something foul.
Symptoms:
Rotten egg smell
HID lights acting weird
power steering going out intermittently
Copped a much better battery to deal with the increased power needed for 4 hid lights.
Hope This helps.
MEAHT
Symptoms:
Rotten egg smell
Hope This helps.
MEAHT
#71
I almost quit reading this post, because I thought it was a mistake. Who could imagine any connection between HID headlights and my power steering going out? But I did keep reading, and eventually I went downstairs to try turning off my headlights, which had been in the AUTO position, and started my car. Lo and behold, my power steering was working again. I just had my left H ID headlight replaced about two weeks ago, following an accident. I will take it to the dealership tomorrow and have them move the ballast elsewhere in my engine compartment.
This forum just saved me an enormous headache, because I am more than eight hours from home. Thank you!
#72
i continue to have the P/S error and power steering failure intermittently -- fails more than it works. Dealer says it can't communicate with power steering and I need to replace the steering rack for $2800, but I can't help but think it's a simpler fix. I had my HID headlamp assembly replaced three weeks ago following low-impact accident. I'm sure it's after market, but it was $600+.
By the way, I talked with a non-dealer Lexus service provider who said that only the dealer can replace the rack because it has to be programmed and calibrated. I just had my water pump replaced at the dealer, and it was much higher than it would have been elsewhere. I feel trapped.
Can anyone suggest what else I can try before replacing steering rack? If it works intermittently, can it be saved or is permanent damage done?
#73
#74
I just went through this. Thanks to all who added to this thread. Picked up a PS ECU at the junk yard for $150, swapped it and my IS is back up and running. My HID ballast for my fog lights are no where near the power steering ECU. So idk if that was the cause, mightve just been its time to clock out.
#75
very helpful thread, no wondering after head light replacement my is250 has a slightly pull to the left, i forgot to tight one of the bolt from the right head light, when i was messing with my Grill i found out and tighten it up, the car now perfectly drive straight somehow, too much power = headache, oh ya i was looking for the P/S fluid reservoire all morning could not find it so does the Trans dip stick, now i know is250 don't have one.
