Headlight Aim
I have non HID headlights with aftermarket HIDs. i recently had to remove my HIDs and put the factory bulbs back in so the dealer would do some maint. but now that i installed the HIDs the aim on the driver headlamp is lower than usual.
Does anyone know how to adjust the vertical aim on the headlamp.
IsD, yes, ISx50's can come without HID's, but they still come with projector housings.
I just installed my aftermarket HID kit this past weekend and had the same problem. If you look behind the housing, there's a bolt that's painted silver (painted or naturally, can't remember). You'll need a wrench (i think maybe 5mm or smaller) to get at it. Turn it clockwise to raise the height of the beam level. It's a tight area, so it's a little bit of a pain in the ***.
I hope that's right, 'cause that's what I did. lol, but it increased the height to where I want it and the beam pattern is good. Hope this helps.
archangels
RX - 1st Gen (1999-2003)
05-07-08 04:17 AM
