TPMS scam or legit
One of the reasons for not reporting the actual tire pressure per wheel was the alleged inability of “older” drivers to comprehend it. Also for what it might be worth Toyota was among the companies wanting simple reporting. What we ended up with was a standard that was acceptable to all TMPS component makers, the car makers and some of the “consumer” groups.
Obviously because of the low cost there was no point in requiring a universal interchange standard to keep replacement cost (and retail dealer profit) down.
I guess it could be worse; we could still have the 55 mph limit.
Well I picked up the car and didn't let them continue rape me![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I'll take the suggestion and buy a TPMS from eBay then bring it to a Toyota dealership to have this done.... as it seems I can't disable this !@#$%^& TPMS
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Tech Info Resource
From here.
TPMS Toyota Fault Diagnosis
TPMS replacement is called for when the TPMS fails due to mechanical or electrical failure, broken accelerometer, low TPMS battery power or blocked pressure port. One of the most common causes of failure is inappropriate handling during wheel or tire removal or servicing. The TPMS is an electronic component fitted as part of a heavyweight mechanical process.
Great info thanks for digging this up. In retrospect i should have asked for the tech to provide the final audit as this would have confirmed that they were not at fault.
Acutally don't think this would be the case as it takes a couple hundreds clicks to spit out an error code.
Tough one
Tough one
And yet if you buy a caddy, which stereotypically has older drivers, it reports the exact pressure in each wheel.
Even sadder, buy a cheap chevy and it does the same thing...making the Toyota/Lexus method of "Hey, something is low, good luck figuring out what and how much!" look even worse.
Received 1,063 Likes
TPMS has worked great for me...
It has notified me of several low tires (due to nails) before I leave for work in the morning and go do 75mph on 25psi
I have no issue checking all 4 tires to find the one thats LOW..
It gives me a piece of mind knowing the rest are good as well.
Plus, I do it once a month already..
Any NEW sensor ID can be inputed into the system out of a tire.
It just won't initialize or remove the TPMS warning light, until the sensor is correctly pressurized..
Thats mainly why the dealers won't input the numbers with out properly installing the sensors in wheels & tires.
- Joe Z
- Joe Z
Super Moderator
Tech Info Resource
The temperature and pressure information is available, just not displayed unless you have a scantool connected to the OBDII port. The scantool will decode the packets from the TPMS ECU and tell you the real numbers. Lexus just didn't see fit to put this software into our combination meters. If anything cries out for a reflash benefiting all owners, this is it.
Joe - I don't disagree it works. It's just not as good as the competition, and it's pathetic it doesn't tell you which tire is low. Sure it's great to be prudent and check them all, but I shouldn't have to do this when the data is there but Lexus chooses not to display it.
Heck no! He was just trying to find a way to get more money. I just got off the phone with a very helpful Advisor from another dealership and actually told me some good useful information on what to do so I'll be taking it to Lexus of Carlsbad once I get the sensor installed by Discount Tires and just provide them the number thats on the sensor.
The other Advisor did not mention that to me, so it seemed like I was pretty much screwed.
I hate TPMS sensors and I think they are pretty useless. Whats the point on having them on anyways when you have to check all four tires once the light comes on. You would think it would at least tell you fronts or backs are low so you atleast have a 50/50 chance of guessing which one is low rather then a 25% chance.
I am purchasing a new set of tires, but the site is trying to get me to purchase a TPMS Rebuild Kit. I am assuming that I only need to replace the tpms kit if i am changing rims, but dont replace them if i am just changing tires...correct? According to the site "I must replace the wearable components of your TPMS sensors each time a tire is replaced or serviced"
I got my TPMS sensors from e-bay for $52...and discount tire programed them for free!....they said they do all programming for free with all TPMS,lexus wanted $180 to do all 4!
Sorry for bringing this back from the dead but I feel the complexity and cost of these tmps systems is completely unnecessarily high. They have managed to turn a safety system into a huge money maker. If the point was to actually increase safety you would make the system much easier to program and repair. For example each car could have the ability to program it's own sensors. Make the valve stems removable threaded on from the out side so anyone could go to wall-mart and replace them. This is how the 1% make billions. Personally I will never fix it. I can handle the little light on.
