TPMS scam or legit
I purchased a newer set of tires and rims with TPMS that was fully functioning from a second party .
The car however doesn't recognize the signal from the new set once mounted of course and shows the signal on the dash to indicate this.
So I have the dealer break the bead on all four rims and activate the new sensors .
Well 200 miles later the warning signal on the dash is back again.
Take it back into the dealer and they tell me the right rear sensor is faulty .
So they want another $90 parts plus labor probably $150-$175 out the door
They really have me over a barrel here and it seems fishy to me.
I have not given them my approval to go ahead yet as I wanted some feedback from the forum.
Am I just being too cheap & suspcious or does anybody else think somethings up.
Other than asking for the faulty sensor how do I hold them accountable
Thanks for the reassurance and the suggestion on ebay.
Don't know why I didn't think of it I am usually the ebay hound =0)
Guess I am still trying to get my head around why this wasn't detected first time around?
Maybe I haven't searched enough.
Are these sensors known for a high failure rate?
You may be on to something with the weather change as I brought the car up to the Pacific NorthWest from Vegas just this summer .
Are the batteries replaceable?
Anyone with more technical expertise than me know if this service kit could be a fix to the failed sensor?
http://cgi.ebay.com/ebaymotors/TPMS-...Q5fAccessories
Unfortunately the batteries are not replaceable. The sensor need to be change cause the batteries are built in the sensor.
Good luck........... Edz
So I dropped off my car for a 35K Service, Fuel Pipe Recall, and to replace my front pass sensor. The dealership is charging me $289.50 for parts and labor for replacing the sensor.
I thought that was pretty high so I called another dealership in San Diego and the Service Advisor said it will cost $120 to program the sensor and $113 for the sensor. So I decided to just leave it at the dealership and get it done since I'm sure it will cost the same.
Just got a call from the Service Advisor and he said the Tech's will not remove my tire since I have aftermarket rims.
I asked if they can just program the sensor and I can take it to a tire shop and get it installed but he said that they cant do that since it needs to be inside a tire for them to program the sensor?
But he did offer me to scan all 4 tires for $120 to make sure all the sensors are up and running.
Now I need to find a place that will program the sensor.
Heck no! He was just trying to find a way to get more money. I just got off the phone with a very helpful Advisor from another dealership and actually told me some good useful information on what to do so I'll be taking it to Lexus of Carlsbad once I get the sensor installed by Discount Tires and just provide them the number thats on the sensor.
The other Advisor did not mention that to me, so it seemed like I was pretty much screwed.
I hate TPMS sensors and I think they are pretty useless. Whats the point on having them on anyways when you have to check all four tires once the light comes on. You would think it would at least tell you fronts or backs are low so you atleast have a 50/50 chance of guessing which one is low rather then a 25% chance.
