Sirius Satallite factory installation
Hi! I'm new to CL finally bought my new Lexus IS250 AWD, my first Lexus was an IS300 really excited to be part of the 2nd Gen Lexus family.......Now here's my first post hopefully someone can help me....I'm wanting to install Sirius Radio into my car but the dealership is charging me an arm and a leg but I found this on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
It's a plug and play device has anyone installed this in their IS? Any problems? Please let me know...Thanks
Get the XM kit instead. Since they merged you can get just about identical programming on either system, and the XM kit is a MUCH easier and MUCH cleaner kit to install. Cost will be about the same if you get it from Sewell or one of the other forum vendors.
The XM kit installs 100% in the trunk, is totally plug and play, and requires removing nothing but a couple of plastic trunk panels.
The Sirius kit installs under your seat, and requires taking the dash apart. Plus it doesn't use the factory Sharkfin, you'll have to install an ugly external antenna (or spend $50 on an adapter and still run the wire yourself)
That Ebay kit is by VAIS, it's not the factory kit BTW. It'll work, but it's still a much less elegant solution than the OEM Lexus XM kit.
I installed this kit in my 09 IS.
complete plug and play and EXTREMELY easy to do.. it plugs in to the back of the radio and mounts under the passenger seat. however . on the IS there is alot of room behind the radio to properly mount. do it... its so easy a caveman can do it!
I have a 2007 IS250 I brought it to the dealer and on 06 to 08 they dont come with satellite radio its an option they can add on. I'll most likely buy this kit on ebay and hopefully dont mess anything up. I'll post up some pics after installing.
Kinda handy around a car, and don't mind taking a few trunk panes off to do it. Does the XM use the shark fin as well? Thanks
OK, I will bite. LOL What is the XM kit link? We also have the 2007 IS250 AWD, no ML radio,6 Cd changer but our radio does have the aux/Sat button and the shark fin antennae. We are currently using a sirius portable that we plug into the AUX jack on the radio, but we then loose the cigarette lighter plug that we would rather use for the Christmas present GPS.
http://www.sewellpartsonline.com/par...id=90062&all=Y
I'd call em on the phone to verify it's the right part for your year, and use the 10% club lexus promo code... but other than removing a few trunk panels the entire thing is plug and play, all done in the trunk, plugs right into the shark fin connector, ends up being exactly like if you'd ordered the XM option from the factory. WAY easier than the Sirius OEM install.
darden
IS - 1st Gen (2001-2005)
05-04-04 10:26 PM
