Wierd stutter when wheel turned all the way
So i noticed that my car stutters or does the shimmy when i turn my wheel all the way to the left or the right. When i mean by stutter is the motion is like a manual car about to stall. It does this in drive and reverse. It only does it when my wheel is turned ALL THE way.. but drives normal when taking a turn. Any ideas?
Does it happen on all surfaces? I noticed my car does that sometimes , but usually on really really smooth surfaces.
Did u notice this before? or is it a new thing?
i have the same problem, but i;ve also had my steering rack replaced after it failed and was fixed for free on recall, so wondering why they did not fix this aswel
I hit a huge pothole not long ago and bent my wheel slightly. Mine now exhibits the same symptoms as you're describing while I'm moving forward or backward at a slow speed have the wheel turned lock to lock. Dealer said it was indicative of a bent wheel.
Can't be low pros and camber. I had that since my first tire change and lowered my car. Nothing.
newpuy
05-11-10 08:00 AM
