any one kno how to take off sun roof panel?
does any one know how to take off the sun roof panel please chime in...
i did a search and all i come up wit is the light panel on top. i just need to remove the sun roof panel thing that moves back in forth, to get some dirt out.
why cant you just open your sunroof fully, and shimmy the panel? it's not solid and im sure it can bend every which way without damage. you can just vacuum from the outside then.
Tech Info Resource
It all depends on how much you need to remove. The factory service manual tells you how to remove the entire assembly - headliner, left and right airbags, left and right garnishes come out, then there are four Torx 25 screws holding the glass itself in place. Depending on what you have available for tools you might be able to remove the glass by just removing the Torx screws.
Since I haven't done this myself, I can't say one way or the other what will work, but I can say if you follow the factory method, it's a LOT of work.
