How hard is it to install HID?
^^^^^^^^^^^^^^YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DDM HID's have a lifetime warranty and they have a kit for only $30!!! I just installed some in my car two weeks ago. If anything goes wrong, just call them up and they'll send you a new one.
As for the ease of install, it's harder than people are saying it is. I just did it two weeks ago, and it took a few hours with me and someone else who has installed hid's on other cars and motorcycles.
The install guide is ok, it's missing some things. use both club lexus's install guide and my.is install guide. the my.is install guide pinpoints where the bolts are.
one thing both of them are missing is a more elaborate how to of taking out the airbox:
-loosen the nut that holds the clamp to the airhose and unclip the sensor
-unclamp the top half of the airbox as if you were changing the air filter
-take off the top of the airbox and pull out from the airhose
-now the bottom half is where i got confused because the instructions said nothing of this.
-the bottom half is connected to a snorkel which brings in air from the front center of the car. the snorkel is held in by a bolt and a clip which you have to pry with a screwdriver. you MUST remove both the snorkel and the bottom half of the airbox at the same time.
-unbolt and unclip the snorkel, and unbolt the airbox (tricky because you need a ratchet extention, i was lucky enough to be in my dad's garage where he has one).
-pull out the airbox and snorkel STRAIGHT UP (there's a two inch stick attached at the bottom of the airbox that goes into a rubber seal, so it feels like it's stuck in place, just pull hard up)
Another things was the dust panel.
-drill a 1 inch hole (buy a 1 inch bit, don't cheap out)
-on the inside are these grid pattern extensions, use cutting pliers to snip them out (i couldn't figure how to get rid of them so i used a million different tools and cutting pliers worked the best)
-remove the existing bulb by twisting counter-clockwise. install hid bulb by twisting clockwise
use a sealant on the outside (i used silicon caulk)
for the windshield wiper tube, just pull straight up
store your panels somewhere, no point in having them in your car once you've taken them off.
to summarize: buy ddm (they're the best deal i've found), do it yourself, it's not that bad now that you have information that fills in the blanks. oh, and buy 6000k, you won't regret it.
it's not hard at all; for me the hardest part was finding where to stow the ballast. for most HID kits, the ballast is pretty big, but luckily this last set that i got the ballasts were tiny and thus fit perfectly. took me quite a while but it was my first time.
HID installation is pretty easy, as others have said. Just don't try to rush installation, as it should only take like 30-45 minutes anyway for a first time. Don't get dirt on the bulbs.
i did it myself and i also use the hidextra hid kit on my car... i had it bout 4 months and its working just fine... and the first time it was kinda hard but den u get use to it and i did it again and it only took me an hour...
LINSTEFAN
02-12-15 07:33 PM
tim817
04-01-08 12:45 AM
