Does anyone have this problem......
Sometimes when either the heat or the AC is on a certain blower and the fan is at a certain rate of blowing out of nowhere it changes. The inside circular air switches to outside, and the air blow either harder or softer and than the temp switches! any ideas? Thought i would hit you all up before i had to drop it off at the lexus dealership.
THanks,
Lazar
THanks,
Lazar
I'm little confused on what you are trying to say on your first sentence..![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
anyways,,I believe the air would blow either harder or softer and the TEMP would change if you press the AUTO mode![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
hope this helps
hope this helps
KGK
NX - 1st Gen (2015-2021)
11-12-16 06:14 AM
