entire center climate control/ML navi DEAD!help!
hey i've had my sub hooked up for a while now and decided to go with a stronger amp.So while switching amps i guess i switched wires wrong somehow and blew a fuse.but the thing is that i checked the fuses under drivers feet/both drivers and passenger sides of engine bay and all fuses are good.I pulled out ML/navi/climate control and all wiring and everything seems to be good.Everything was working fine until i switched amps now my entire navi/climate control doesnt work,it doesnt even light up not even my clock...if anybody has some ideas or knows anything input is appreciated...i also dont want to take it to the dealer cause i did the navi hack and i tapped into ML amp to hook up subs so voided warranty.Thanks in advance.
Nevermind.I found the problem...i didnt know their was a fuse box located on the passenger side feet also...its labeled radio #3 for those who run into this problem...10a fuse
jason14
12-21-13 09:34 AM
