rain messed up my headlight!! =[
hey guys i have warranty for my car for 3years if my hid and headlight is messed up can i bring it back to the dealer and they fix it or give me a new one? but i changed my fog lights bulb to yellow would i have to change it back to the oem bulb or would my warranty be void???
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
fog lights should have nothing to do with your the low beams, and they can't reject repairs if you have yellow bulbs in your fog light housings.
however, imo the only way rain will mess up your 2is lighting system is if it was altered or modified in any way - including faulty equipment installation - and moisture some how got into the housing and short-circuited something. if that's the case, you're on your own on that one.
i didnt touch anything tho all i touched was with the yellow fogs -___- but there was water inside the headlights tho and when i checked out the bulb and harness it was moist -___- so i tired to blow dry it and everything. how much would it be to buy a new oem hid kit and new headlights? kuz the headlights is all fogged up
if there's moisture inside the headlight housings, either the headlight housing seal is coming apart, or moisture got through the D4S bulb hatch.
but since you didn't touch your headlights or access your D4S bulbs (or so you say), this should qualify as a warranty repair - assuming that your warranty is still in effect.
learn how to write and describe things, then we can help you better.
if your fogs have condensation in them, then yes, change the bulbs back to normal. they'll take care of that under warranty (assuming you didn't damage anything).
HIDs are a pain in the *** to get replaced.
$300-$400 for the BULB if it's that. $1500 for the controller for the HID. You have one on each HID. Sucks right?
Smack the headlight a couple times. If it comes back on it's the bulb. If not, most likely it's the controller. My GS300's controller went out over the weekend because of the rain. Water collected or something, it's just poorly designed.
damn! so u sent 3000 just for the hid controller? O.o or 1500 for both? damn thats expensive but i just bought my car tho i can return the car still if i wanted to so it should still be under warranty know?
