19s or 20s? Cant decide.
Old 12-29-09, 11:35 PM
PlatinumIS
PlatinumIS's Avatar
Default 19s or 20s? Cant decide.
Looking to get some wheels soon but cant decide whether to get 19s or 20s.
As of now i choose to drop it on springs unless i find some coilovers for a great price but i think 20s will make it look like a 4x4 without a Slam.
I also want 19s because the ride will be smoother and look fine with a drop on springs.
With 19s what widths could i go with, im thinking 19x8.5 in the front and 19x10 in the rear. With those sizes, do you think i will have rubbing issues. I think i found the wheels just gotta order them and paint them
Thanks.
Old 12-29-09, 11:58 PM
Rolando
Rolando's Avatar
Dude, all depends on the offset. Low offset looks sick but rubbing will drive you nuts unless you fix the fender. If you go to the thread where is says crappy is250/is350 cell phone pics I have my car on 20s and 19s and believe me 19s feel so great is crazy. The car looks awesome on 20s but the ride quality sucks all depends if there is a lot of potholes because in NY specially manhattan there is a lot and ride quality is wack so I switched.
Old 12-30-09, 12:22 AM
PlatinumIS
PlatinumIS's Avatar
Thanks, i understand the offsets, im debating on 19s or 20s because of the ride quality and dont want the wheel to look to big OR too big.
Old 12-30-09, 12:33 AM
Sytfu_IS
Sytfu_IS's Avatar
I have 19's and so do most people on here, 19's look perfect for our car. They don't look too big or small and you can run more aggressive settings on 19's and ride way lower with a drop on 19's.
I would get 19x9 offset 34-36 and 19x10.5 in the 40's you might rub if your on springs and fat tires but if your on coils, you should be fine.
Old 12-30-09, 12:38 AM
PlatinumIS
PlatinumIS's Avatar
Thats what i was thinking. I might go with a 19x10 in the rear and put on a spacer. Im not trying to roll my fenders or heat them or touch them at all so lets hope.
Old 12-30-09, 12:41 AM
Sytfu_IS
Sytfu_IS's Avatar
Well if you want a 4inch lip, you're going to need to roll fenders or shave them. For a 3inch lip, it's pretty easy to get but imo doesn't look as good. If I could do it again, I would've shaved and rolled my fender for some aggressive rims...looks 10x better but everyone got their own preferences so I hope your not thinking of getting a 2inch lip in the front and a 4inch in the rear without some fender mods and aggressive offsets haha
Old 12-30-09, 12:52 AM
PlatinumIS
PlatinumIS's Avatar
I agree and i would prefer that but my cars a lease so im thinking of 19x8.5 and 19x10.
Old 12-31-09, 05:06 AM
mindf
mindf's Avatar
Anyone care to explain that springs could rub instead of coils? Not because the fact that coils can be adjusted to a higher ride?
Old 12-31-09, 09:36 AM
edgeucated
edgeucated's Avatar
i think the general consensus is 19 haha
Old 12-31-09, 11:52 AM
Jetfire
Royale with cheese
Jetfire's Avatar
dare to be different? get 22" spinners from walmart.
Old 12-31-09, 12:13 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,238 Likes on 1,357 Posts
Hi, I'd suggest starting off by searching for other posts to get some idea as this question has been asked and discussed before.
Go to advanced search, put in keywords '19 or 20' and select the 2IS forum. Here are some of the results among others...
https://www.clublexus.com/forums/is-...they-cant.html
https://www.clublexus.com/forums/is-...need-help.html
https://www.clublexus.com/forums/is-...-on-which.html
https://www.clublexus.com/forums/is-...nions-pls.html
https://www.clublexus.com/forums/is-...0s-vs-19s.html
Old 12-31-09, 02:29 PM
PlatinumIS
PlatinumIS's Avatar
Thank you. This was very helpful, im pretty set on 19s.
Old 12-31-09, 02:47 PM
Initial G
Initial G's Avatar
I'd go with 19s. What kind of rims are you planning on getting?
Old 12-31-09, 02:54 PM
Sytfu_IS
Sytfu_IS's Avatar
On coils, they usually come with a stiffer spring rate and you could also adjust the dampening to them which could make it stiffer or softer.
Old 12-31-09, 05:22 PM
IS-SV
IS-SV's Avatar
19's work best for a car that's meant to be driven on public roads.
Quick Reply: 19s or 20s? Cant decide.
