Easiest way to install GFX front lip?
I am wondering what is the easiest way to install the GFX front lip, will 3M tape work just fine? OR should I drill holes just to be safe? I would prefer not to drill holes, but if 3M tape isn't durable enough I guess there's no other choice. Thanks.
The bottom of the GFX lip uses the same screws as the oem lip... the top will be fine with just 3M tape... Just pop out the clips on the GFX lip so you dont have to drill a hole in your bumper for them to go through
yeah just like he said i was gonan drill holes in mines but i was like forget that soo much work i just put screws on the bottom and use the 3m tape that was on the lip and i was good too god never had a problem yet
What everyone else has said is correct. You should be fine with using the 3m tape that came with the lip and the screws. If you're worried, add some more 3m tape. I've had mine on for awhile without drilling and everything is still in place. If you need any additional help, shoot me a PM. Where in SF are you located?
Um ... I could be mistaken but I thought the 06-09 GFX front lip was incompatible with the 2010 models.
that's what I did. i didn't even use the factory tape that's on there. just used 9 screws. I interchange between GFX and Fabulous for winter/summer setup, so i don't really want to stick the 3M taple knowing I will remove it for the summer. You should be fine with just the screws. don't drill.
